Front Axle Alignment question
Old Dec 1, 2009 | 12:18 AM
Danspeed1's Avatar
Danspeed1
I have a feeling I am going to hate the answer to this question. I am doing u-joints on the front end of a 1985 Ford F350 6.9L Diesel. Does the alignment of the axle's matter? Does the alignment of the axle to slip yolk matter? I just realized I didn't mark anything while removing it. I am hoping this is not like a driveshaft.... I am not going to get any vibrations.
DG
Old Dec 1, 2009 | 06:48 AM
bashby's Avatar
bashby
I always line up the u joints when I put the slip yoke back together, but I have seen a lot of peopple that dont bother. The axle only spins if the hub is locked and I dont know if you'd be able to notice much difference with the axle out of phase or not
Old Dec 1, 2009 | 09:43 AM
Franklin2's Avatar
Franklin2
Alignment only matters if you are dealing with more than one u-joint. So the driver's side axle doesn't matter. The passenger side does. For the u-joint on each end to work together, they need to be in alignment. This also applies to the front driveshaft with the slip yoke, and the rear one also if it is the slip-yoke type like the front.
Filko
18
Jan 15, 2015 01:46 AM
zombiefied 247
Oct 16, 2013 07:08 PM
Andy Sullivan
Sep 29, 2012 07:42 PM
RIKIL
Mar 11, 2009 12:10 AM
dzwiss
All Things Towing
Oct 29, 2008 12:03 PM
