Head gaskets???
Old Nov 29, 2009 | 11:16 AM
11secdsm's Avatar
11secdsm
Head gaskets???
I started my truck up as usual a couple minutes ago and noticed a coolant puddle forming under the truck. I immediately turned the engine off and started taking a look underneath. On the driver's side I had a clear view of where it looked like it was coming from...the back of the head where it meets the block. On the passenger's side I don't have a clear view but can see it's coming from above the starter. It's definitely on both sides in the back. This is on a 2004 Excursion 6.0. I checked the coolant and it didn't look like it was mixed w/ oil. Also, there was no white smoke coming from the exhaust. I just drove the truck last night and didn't have any blown headgasket signs.
Do I have blown gaskets or is something else going on??? Any advice would be greatly appreciated.
Old Nov 29, 2009 | 11:27 AM
brickie's Avatar
brickie
Most likely the EGR hose,it is in the valley just in front of the turbo on the passengers side.If it is leaking it is most likely red/orange colour.It is an easy fix twist lock.
Old Nov 29, 2009 | 11:38 AM
bpounds's Avatar
bpounds
Easy, once you get to it.
I agree that it's most likely that hose. Heads don't usually leak coolant externally.
Old Nov 29, 2009 | 11:51 AM
11secdsm's Avatar
11secdsm
Is the EGR hose you are referring to the one that goes from the degas bottle to the valley in front of the turbo? Or is there one that i'm not seeing?
When I look at the crease where the block and head meet in the back it's wet on both sides and stops 1/2" up. I see the wet spot going up to the area you guys are referring to but the valley up top is dry. (from what I can see).
Old Nov 29, 2009 | 11:52 AM
11secdsm's Avatar
11secdsm
edit......
Old Nov 29, 2009 | 11:54 AM
11secdsm's Avatar
11secdsm
Found a thread about the hose you are referring to...let me go check this out...
Old Nov 29, 2009 | 11:59 AM
texans's Avatar
texans
Egr hose will be under the hose comng from the degas bottle. It's short look under the oil filter and a little to the passenger side you should see it.
Old Nov 29, 2009 | 12:00 PM
bpounds's Avatar
bpounds
I hope that's it, but you are getting a lot more coolant spraying around than most failures. Normally these start out as a slight drip down the passenger side rear of the block. But I guess it can fail all at once, like any other component. First picture below shows the hose.
Old Nov 29, 2009 | 12:03 PM
11secdsm's Avatar
11secdsm
Found the hose...doesn't look like it's the culprit though. The valley underneath it is greasy but does not have coolant in it.
Any other possibilities?
Also, since the coolant isn't mixing w/ oil, can I drive the truck to my shop to get a better look at things?
brickie's Avatar
brickie
Page 74: Unique Service Procedures If yours is this color it is most likely the source of the leak.
Old Nov 29, 2009 | 12:21 PM
11secdsm's Avatar
11secdsm
I started the truck again hoping I could see where the coolant was coming from easier but unfortunately (or fortunately) it's not leaking now. I let it run till it came up to temp and saw nothing now. The EGR hose is a dirty version of the orange hose so maybe it is it but I can't explain why the valley below it is dry. Perhaps it's running down the line and not dripping into the valley?
Assuming I keep tabs on the coolant level, can I drive the truck to my shop (20 miles)?
Old Nov 29, 2009 | 12:24 PM
bpounds's Avatar
bpounds
As long as there is no oil in the coolant, and no coolant in the oil, I would say absolutely no problem.
BTW, that little hose is notorious for leaking when cold, and not leaking when warm.
Old Nov 29, 2009 | 12:27 PM
brickie's Avatar
brickie
Yes you can drive it.Bill you got some quick fingers today.LOL
Old Nov 29, 2009 | 12:29 PM
11secdsm's Avatar
11secdsm
Thanks guys! I'm going to take the truck to my shop tomorrow and see if I can figure things out. Hopefully the local Ford dealer stocks that part (probably not w/ my luck)! I'll update later tomorrow...
fallguy
Modular V10 (6.8l)
13
Jul 7, 2011 05:19 PM
donjuanit0
Modular V8 (4.6L, 5.4L)
Mar 9, 2011 04:10 PM
Pickupman2004
Nov 17, 2010 05:34 AM
benbe71
Sep 24, 2010 01:40 AM
DutchmanAZ
Dec 22, 2001 12:22 AM
