Guage install???
Old Nov 28, 2009 | 09:01 PM
99hunter's Avatar
99hunter
Guage install???
I tride the serch tool with out much sucess. Is there any good links to videos, instructions, or other for guage wiaring and instalation on the ISSPRO 2's boost and egt?
Thanks in advance Brandon
Old Nov 28, 2009 | 09:32 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
They should come with complete color instructions. You will need a letter 'R' drill bit and a 1/8" NPT tap for the pyro probe install. Everything else should be plug and play.
Old Nov 28, 2009 | 09:43 PM
99hunter's Avatar
99hunter
I'm sorry Clay Machanical I can do, electronics I am not very good at so any help would be great.
By the way I hope you had a good weekend Off with out me buging you. Ha Ha!
Old Nov 28, 2009 | 09:51 PM
hucka1a's Avatar
hucka1a
Gauge Installations at DieselManor- 1999-2003 7.3L Powerstroke
Old Nov 28, 2009 | 09:57 PM
99hunter's Avatar
99hunter
Thanks Huck! Those look like mechanical guages, less wiaring. Is there any differance In the wiaring? Sorry for the incompatince
Old Nov 28, 2009 | 09:59 PM
99hunter's Avatar
99hunter
If I pluged and Played I would bern the thing to the ground
Old Nov 28, 2009 | 10:08 PM
binuya's Avatar
binuya
I recently installed the EV2's, and I am a complete idiot when it comes to automotive wiring. The hardest part for me was locating adequate switched power to run the gauges. (I wound up adding a piggyback fuse adapter to the panel). The instructions for the EV2's are straightforward, but you need to look very closely at the diagram and picture to ensure proper orientation of wiring up the plug.(I inadvertently got one of the plugs in reverse order). Once I stumbled through it, I was quite pleased with them. My problem was trying to rush the process. Take your time and you'll be fine.
Old Nov 28, 2009 | 10:17 PM
99hunter's Avatar
99hunter
Thanks Alvin I will look at them tomorrow and slow down.
Old Nov 28, 2009 | 10:20 PM
hucka1a's Avatar
hucka1a
You'll do fine. It's as easy as falling off a log.lol Just take your time, the EV2's are great gauges and IMO easier to install than the ev1's.
Old Nov 28, 2009 | 10:24 PM
99hunter's Avatar
99hunter
If thats the case it's a good thing Clay talked me into the EV2's.
Old Nov 29, 2009 | 09:40 AM
PaysonPSD's Avatar
PaysonPSD
If you can't find an "R" drill bit use a 21/64" bit. Worked perfect for me.
Old Nov 29, 2009 | 09:44 AM
HKusp's Avatar
HKusp
That was my impression as well.
Old Nov 29, 2009 | 12:37 PM
00Dave's Avatar
00Dave
I remember how worried I was when I installed my gauges. Everyone was very supportive and told me not to worry, just use the instructions. WEll, everyone was right and it was a lot easier than I thought it would be. That being said, just take your time and look at the instructions/links provided and you should be fine.
Old Nov 29, 2009 | 12:45 PM
Izzy351's Avatar
Izzy351
And let us know if you've never tapped before -- there's a technique to it......
Old Nov 29, 2009 | 02:04 PM
canister's Avatar
canister
Could you explain it please. I'll be doing mine next week and that is the only part that concerns me.
