Stuck Tailgate
Old Nov 28, 2009 | 06:44 PM
SouthernBlues's Avatar
SouthernBlues
Stuck Tailgate
I have to pull my tailgate handle 3-4 times before it will open, what could be the problem
Old Nov 28, 2009 | 06:56 PM
Volvo92906's Avatar
Volvo92906
latching mechanism? I think there is a cover you can take off and see the connecting rods. Activate the handle and just look at slack or something in there. Just my guess.
Old Nov 28, 2009 | 08:02 PM
phoneman91's Avatar
phoneman91
There is a long narrow cover near the top of the inside tailgate.
Remove the screws and this cover and the long rods that lock that two ends of the tailgate will be visible-as will be the inside of the handle. Shoot fluid lock graphite lubricant on all of the wear areas. Check and see if the handle will move the long locking rods easier after the lubrication has been applied.
I did this when I installed a lock for my tailgate handle. The lock lubricant really makes a difference. Spray this lock lubricant into your doors locks too-really makes them work like new.
Old Nov 28, 2009 | 10:50 PM
SouthernBlues
Thanks will try that tomorrow
Old Nov 29, 2009 | 11:09 AM
SouthernBlues
Thanks for the info, sprayed everything with lock graphit and it works great
Old Nov 29, 2009 | 11:42 AM
hotrod351's Avatar
hotrod351
mine was opening hard, i really had to pull up on the handle hard, so i took off the plate and readjusted the rods, now it works easy.
Old Nov 29, 2009 | 01:07 PM
robc2064's Avatar
robc2064
Amazing how much better things are with a little lubrication
Old Nov 29, 2009 | 01:22 PM
CincyF250's Avatar
CincyF250
Isn't that the truth. haha
My mechanism was so jammed up the previous owner broke the handle off, just got done fixing that mess this afternoon.
Old Nov 29, 2009 | 10:20 PM
phoneman91's Avatar
phoneman91
You are welcome ,Sir. That lock graphite lubricant is also great for power antenna. The graphite has great lubricating qualities-but doesnt attract dirt.
Old Feb 5, 2011 | 10:40 PM
Lonewolf54's Avatar
Lonewolf54
I just figured out what was wrong with my stuck tailgate.
I tried lube but no hope
I removed the access panel and the mechanism pulled on the latch OK
but it was still stuck firm
after pulling back the weatherstrip and looking at the latch through the crack from inside the bed, I noticed something white down in the latch
It looked like a granite rock so i got a punch and hammer and crushed the rock
the tailgate opened right up
evidently there is a cup shaped pocket in the bottom of the latch.
when hauling gravel it can get stuck in that pocket causing the latch to not fully open
I cleaned the gravel out of both latch mechanisms and it works again
coastaldc
Jan 18, 2017 10:39 PM
Loganwildman
Feb 10, 2015 06:18 PM
FordTruck Forum
Aug 11, 2014 07:23 PM
Memphis_Sean
Jun 7, 2014 11:13 PM
Memphis_Sean
Apr 12, 2014 09:03 AM
