Help with loose starter
Is there a third bolt on top? Would it be on the truck-front side of the solenoid, or the side towards the back?
One of the bottom bolts is loose enough to turn by fingers already, but there is also a sticky point in the threads...could enough grit have gotten in there that it would have to be re-tapped?
Could engaging the starter twice in this condition have damaged the teeth?
I am working in a small town, which does have a dealer and several franchise parts stores.....what is the best brand of starter to replace it with?
Any other tips on replacing it? It does look like one of the easier ones to get at of all the ones I've ever had to fool with.
Here's a related thread with some info that might help. If your truck has an automatic trans, there should be a bolt at 11 o'clock (Upper), and one at 5 o'clock ( Lower). If you think a bolt may be screwed up, take it out and look at it and take the appropriate action for what you find.
Opinions vary about the best parts. I just put a Napa Premium in my '01 F350 yesterday.
Three year warranty and no made in china stickers on it. I would pull your starter and inspect all related parts for damage and go from there. Just my 2 cents.
Before going to some Loc-Tite on there, I guess I would like to know what the exact recommended torque should be on those bolts? I think I'll go with that and keep an eye on them. I don't know if it is the original starter but I would expect so, and as this truck nears it's tenth birthday I think I'll wait till it is time to replace the starter and then Loc it down like that.
Napa Premium does sound good to me if I had to while a long way from home, otherwise I would pull mine and take it to an AIS equipment service franchise where I live that has a top-quality electric rebuild shop.
I usually hang out down in the IDI forum for my trucks, but I've got a starter question for my Dad's truck.
We never had any symptoms of hard starting, but tonight we had a loose starter. Actually, the lower bolt fell out and left the bottom of the starter about 1/2" away from the automatic transmission.
We were 40 miles from home and in a parking lot...
I was able to pry a jack handle against the oil pan to keep the starter in and start the engine and get us home.
Tomorrow I'll be replacing the bottom bolt and tightening the top bolt!
Any ideas what the length and thread of the lower bolt is?
Good luck and good maintenance.
