Radiator support question
Old Nov 28, 2009 | 07:03 AM
67nukeford's Avatar
67nukeford
Veteran: Navy
Exclamation Radiator support question
I've checked the master parts/accessories catalog, but can't find this info. What is the difference (I'm assuming there is one) between the 6 cyl. and 8 cyl. radiator supports? Does the V-8 support have a larger opening, for the larger radiator?
I'm planning on going Monday to take a look at one a guy has, but I don't want to get the wrong one. Anyone who would happen to have the opening measurements would be much appreciated!
Old Nov 28, 2009 | 07:50 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Engine size has nothing to do with it.
Radiator Support: TEXT, Section 160, Page 8.
C7TZ16138A .. Radiator Support / Use without Super Cooling Radiator / Obsolete
No Ford Dealer or obsolete parts vendor has any.
Fits: 1967/72 F100/250 2WD without Super Cooling Radiator.
C7TZ16138B .. Radiator Support / Use with Super Cooling Radiator / Obsolete
FRED GRANDE FORD in Richmond MI has ONE = 586-727-3415.
No other Ford Dealer, no obsolete parts vendor has any.
Fits: 1967/72 F100/250 2WD with Super Cooling Radiator // 1967/72 F100/250 4WD // 1967/72 F350.
Since the dimensions of the Super Cooling Radiator are larger than the other radiators, the opening radius of the radiator support is larger.
Radiator (basic part number 8005) = TEXT, Section 80, Page 9.
Super Cooling Radiator: 26 1/4" wide x 24 1/8" high x 1 3/4" thick.
Standard Radiator: 26 1/4" wide x 19 3/4" high x 1 3/4" thick.
Old Nov 28, 2009 | 08:16 AM
67nukeford's Avatar
67nukeford
Veteran: Navy
Okay, thanks Bill. Tried to find it on the cd, but didn't see that. I'll take another look. I wanted to make sure the I-6 and V-8 supports were different, since I'm going from an I6 to a 390. Hopefully the one this guy has is in decent shape.
Old Nov 28, 2009 | 08:24 AM
NumberDummy
The difference in the radiator supports has to do with the Super Cooling radiator ONLY!
It has nothing to do with the size of the engine.
If the 240/300/302/352/360/390 engine has the Super Cooling radiator, the radiator support's opening radius is larger.
Old Nov 28, 2009 | 08:49 AM
67nukeford's Avatar
67nukeford
Veteran: Navy
Sorry, Bill, I meant to say "I wanted to make sure the I-6 and V-8 supports were NOT different". Looks like I'll be in good shape either way.
benwantland
Jan 29, 2023 06:35 PM
hillcountryflt
Sep 12, 2015 12:29 AM
Shadowrider123
Jun 17, 2015 01:18 PM
idealtrucks
Sep 5, 2013 10:48 AM
scamardo
Sep 2, 2003 02:09 PM
