i have an 06 powerstroke with the MSOS 4x4. i know that you have to manually lock the hubs and then back up, but i dont know how far and when i do try this, it never seems to lock. can somebody tell me how i do this??
You shouldn't have to back more than 30 ft for it to DISENGAGE. You don't have to reverse to ENGAGE it. If hubs are locked and shifter is in 4wd Hi or Lo you should be in 4WD. Not sure if I answered your question though?
EDIT: Is there anything about it in the owners manual?
It is Manual Shift on Stop. not Shift-on-the-Fly. to engage it you have to back up, but when i do it it doesnt engage. and the book says nothing about engaging it
Every 4x4 truck with floor shift t-case Ive ever owned ,you lock hubs manually , shift into 4 hi at about any forward speed desired and engaged you are.
Nope didn't work either. Even had about one inch of snow to drive in (Indiana). When I turn corners one front tires skids across the road ( don't know which) I tried backing up, didn't work and i tried just putting it in 4HI and going and that didn't work either. Do I need to replace fluids? 4LOW has the same problem, although it does engage, one of the front tires skips the ground when turning.
while moving forward under 55 mph stick it in neutral, then shift the level in to 4X4 high, give it a second to lock in, and put it back in drive, to disengage its same thing just moving the lever into 4X2 position
Well I dont know, maybe the fact that the front wheel skips on the ground when i turn?
I have been in many 4x4s (chevys) but their wheels didn't skip the ground. I know of one time that the 4x4 worked and that was only when I backed it up so far and the wheels did skip the ground after turning twice but none after that.
Forget the Chevy. You are in a real 4WD truck now.
The skipping is because the front axle turns at a slightly different speed than the rear axle, and they are solidly locked together in the transfer case. Something has to slip/skip, and that will be a tire. This is exactly why you don't use 4WD on hard dry surfaces. Don't do it, you risk breaking something. It's fine on light snow, but you will feel the skipping in hard turns.
Sounds like it is working perfectly.
As for the first comment, I'm starting to think that I have been choosing the wrong company and am starting to think about going to a Chevy, maybe the people that have chevys ACTIALLY help me when I needed help instead of sending me off in different directions thinking that they are helping. And the second, thats not true because my uncle is a farmer and he uses 4HI on his Ford and both his Chevys. But wait, their tires don't skip the road. So your wrong. The whole point of 4HI is so you can drive on snow, ice, sand and whatever else the truck may have a hard time getting through normally not able to do in 2WD. What would you like to do, set it in 4HI or LO and drive however far you need to, or would you rather drive until you see something, engage 4HI or LO, pass over it, and then disengage? I'm pretty sure that anyone would rather set it and forget it.
