turbo upgrade
Old Nov 27, 2009 | 11:33 AM
dieselkid's Avatar
dieselkid
turbo upgrade
ok i havea 84 6.9 diesel with a ats upgrade put on before i bought this truck i love my turbo, its awsome on the highway and pritty niffty for towing uphills.... but i would like to upgrade it and get some more boost outa it, i like getting on the highway and some ram trying to cut me off, i have to boost to get away from him but i dont really pull away, so how can i get the waste gage to get more boost though the system.
i know on like car motors u can get new spring for the waste gage and that can pump the more boost, but i know with a diesel it all comes down to can ur fuel pump and other lil fuel managment handel all the extra fuel trying to go thru it. so can stock system handel more the 9psi (i have 9psi right now when punched)??? i would like to get like 15ish at the most, wut is the best way?
Old Nov 27, 2009 | 11:51 AM
starmilt's Avatar
starmilt
More than likely the pump was turned up when the turbo was installed but may not have been. What do you have for exhaust and intake inlets, stock leaves a lot to be desired.
Also keep in mind without head studs on the 6.9's getting above 10 # is putting your head gaskets at risk.
Old Nov 27, 2009 | 11:58 PM
dieselkid's Avatar
dieselkid
oh ya i forgot about the studds and headgaskets alright i dont need to be blowin head gaskets or heads
Old Nov 28, 2009 | 11:14 PM
Dave Sponaugle's Avatar
Dave Sponaugle
The first thing to do would be install a pyrometer and boost gauge.
That way you know how much boost you are running now and how the fuel is set.
Yes you will have a couple hundred in gauges, but it can save head gaskets and pistons which cost more.
Then there would be no guessing, which can be expensive with a diesel engine.
2000F350Scott
34
Jul 11, 2010 06:36 AM
caleb6.9
33
Feb 21, 2010 11:37 AM
cowmilker08
37
Apr 12, 2009 07:40 AM
chadjones99
Apr 7, 2006 10:16 AM
Intercooled
Aug 20, 2003 12:24 PM
