Flowmaster....
Old Nov 29, 2009 | 12:46 PM
lew52's Avatar
lew52
Don't like glass blasters, just make a bunch of noise , I like chambered mufflers , super 44s ....Lew
Old Nov 30, 2009 | 03:24 AM
TexasGuy001's Avatar
TexasGuy001
Originally Posted by zxwut?
You're entitled to your opinion As for the performance thing though, I doubt you'd feel any difference if someone chopped out your glasspack and replaced it with a chambered muffler whilst you were asleep.
My truck runs better with the Magnaflow on it that it did with either of the Flowmasters that were on it before. This is especailly true at slower highway speeds with the AC on. It doesn't lug as much or down shift as much.
I have also read a bunch of different muffler tests that show that Flowmaster is one of the worst for performance.
The difference on a stock or mild motor is probably not very noticable, but it is there.
Old Nov 30, 2009 | 03:27 AM
TexasGuy001
The longer ones are deep and mellow. Most people have the short ones because they want it to be loud. Loud is not necessarily better.
Old Nov 30, 2009 | 04:17 AM
lew52's Avatar
lew52
Yeah everone has there own idea about exhaust systems . I just don't like loud raspey exhaust , i run a very short system that ends at the end of the cab so i don't have alot of room , Similar to a mustang 2 1/2 duals H pipe then mufflers thats it. I don't think i have a problem with backpressure with the 44s . To elimanate back press at the mufflers just run a bigger pipe before the mufflers,then a bigger muffler , like 2 1/2 to 3" pipe & muffler . I never had a problem with drone , i think Conanski might be on to something when he said he just moved his muffler closer to the front of the system & it elimanated the drone ?? ...Lew
Old Nov 30, 2009 | 01:48 PM
1966Tbird's Avatar
1966Tbird
i have always heard mount your mufflers right after the cab if you dont want them to drone. another thing i have heard is just don't buy a flowmaster if you dont' want it to drone
Old Nov 30, 2009 | 01:58 PM
dmmckaskey's Avatar
dmmckaskey
Originally Posted by twister2gt
Do the thrush welded sound just like a 40 series flow?
I put the flowmaster 40 series on my 302 w/o takin out the cats .... it did not give it the sound i was looking for...(actually after a year i really dont think it sounds any different than the stock one)..im looking at doing a strait pipe with resonators....npd sells some like it. but do yall think it would sound good?
Old Nov 30, 2009 | 02:02 PM
lew52's Avatar
lew52
With the cats in there the muffler dosn't do much , with out the cats you will notice the difference .... Lew
Old Nov 30, 2009 | 02:18 PM
dmmckaskey's Avatar
dmmckaskey
so i should cut out the cats?
Old Nov 30, 2009 | 02:26 PM
lew52's Avatar
lew52
Thats up to you . Do you need them for inspection , some guys just run cats with straight pipes with no muffler ....
Old Nov 30, 2009 | 05:15 PM
1966Tbird's Avatar
1966Tbird
i wouldn't gut the cats because that still is a restriction because your exhaust is hitting an open area then getting necked down again to go through the outlet of the cat. If you don't want cats just don't run them, there are plenty of ways to get around emissions testing just look up how many miles you have to drive under to be emissions exempt and adjust accordingly
Old Nov 30, 2009 | 05:35 PM
lew52's Avatar
lew52
X 2 don't gut the cats , replace them with straight pipe, our trucks are 4 strokes , they don't need an expansion chamber like 2 strokes .... Lew
Old Dec 1, 2009 | 03:26 AM
TexasGuy001
I agree, I don't like a really loud raspy exhaust either.
Conanski still doens't like his Flowmaster 50. I believe that is what he has.
He did say that moving the muffler forward did greatly reduce the interior resonance. That just seem like it would do the opposite to me.
Old Dec 1, 2009 | 03:28 AM
  #28
TexasGuy001
If you have both the stock cats, just straight pipe it and see how you like it. It sounds fairly good this way. But you have to run tailpipes. If you dump it like this it just sounds like broken exhaust.
