truck wont start and icpv is low about .24v. icp pressure will only build to less then 100 psi while cranking is a good starting point.
If you remove the ipr valev and the screen is stuck in the pump
if you remove the ipr and the screen is sucked in
if you remove the ipr and the screen has a hole in it
It starts & shuts off about 3 times before it stays running, only the first time of the day I start it. Then it will start the rest of the day. I checked the FICM and had 47.6 all the time.
ok. this could be a number of things. could be a bad ebp, bad icp,injector issues, ficm issues or a internal oil leak.
you will need to find out what base oil pressure is when it happens. If base is low you may have a pump headed south.
so far as an ipr vlave it is possible aswell but unlikly the cause.
No, it start right up then shuts down. Yesterday it start normal, but most times I have to restart it 3 times. But it is not long crank time on any of them.
oil pressure would be suspect if it was long crank
so lets try this.
disconnect icp and see if problem goes away
disconnect epb and see if problem goes away.
try and plug the block heater for 2 hours and see if problem goes away
