Autoenginuity how to question
Old Nov 27, 2009 | 09:23 AM
desertt5's Avatar
desertt5
I picked up AE last week and have a question. Is there a way to check the injectors other than codes and buzz test? Been told by a repair place and the dealer different injectors that are bad or going.
Thanks
Old Nov 27, 2009 | 09:49 AM
cheezit's Avatar
cheezit
I dont know about the ae stuff but I may be abe to give you a little help.
does ae have a power balance function?
does ae have the ability to kill injectors 1 at a time?
If you cant do either you can disconnect the injectors 1 at a time and moniter rpm change and see if rpm drops to the same level with 1 injector unpluged at a time. The injector that drops the least is going to be the bad one(s) this assumes that the condition can be duplicated in the driveway at idle.
Old Nov 27, 2009 | 01:23 PM
texans's Avatar
texans
Very usefull tip cheezit reps to you
