Got a problem, need some help...
Old Nov 26, 2009 | 01:29 AM
HawaiianPSD's Avatar
HawaiianPSD
Friend of mine has a 06 w/ 64K miles. He's got a starting problem with his truck.
It takes some time to crank over but it does fire up. When @ operating temp. it won't start (cranks over strong but doesn't fire). Can be kick started and it fires right up w/ engine hot or cold. Problem got me stumped. Anybody got any ideas??? Thanks guyz!!!
Old Nov 26, 2009 | 06:13 AM
Maxium4x4's Avatar
Maxium4x4
Describe "Kick Start" For a hard start when the oil is warm on an 06, indicates an oil leak at the high pressure pump snap to connect fitting.
Old Nov 26, 2009 | 06:18 AM
bismic's Avatar
bismic
I don't understand "kick start" either.
Here is a thread that can help you eliminate some common issues:
https://www.ford-trucks.com/forums/8...condition.html
Old Nov 26, 2009 | 07:01 AM
Maxium4x4's Avatar
Maxium4x4
I think you are close....... ether
Old Nov 26, 2009 | 11:05 AM
cheezit's Avatar
cheezit
emmm this is mostly going to be covered 5/100 with $100.00 deduct. take it to the dealer.
Old Nov 26, 2009 | 11:10 AM
FireMe's Avatar
FireMe
He has a leak in the high pressure oil system. It takes time and some special tools to diagnose.
All parts of the high pressure oil system are covered by the diesel warranty.
Old Nov 26, 2009 | 12:12 PM
HawaiianPSD
Thanks for the info guyz!
