Common Vacume leaks
Old Nov 24, 2009 | 08:24 PM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD
Common Vacume leaks
Are there any common places to check for vacume leaks? It idle rough, kind of like its missing some. Tried spraying brake clean/carb clean to detect vacume leaks but neather of the cleaners i had would make the engine rev up. Guess i need to find something that will make the engine respond.
Just looking for ideas.
Old Nov 24, 2009 | 08:29 PM
brett12396f150's Avatar
brett12396f150
If it idles rough.....have you done a tune up?
Old Nov 24, 2009 | 08:54 PM
BURNSTOUGHFORD
New plugs, checked ohms on plug wires. Checked air filter. Everything is looking good. Truck runs pretty well. Just shakes at idle.
Old Nov 24, 2009 | 09:34 PM
vancouver island's Avatar
vancouver island
My truck did the same thing. Do you have the original plastic lines? I just replaced all the plastice lines with rubber hose and the truck idles 100% better.
Old Nov 24, 2009 | 10:24 PM
BURNSTOUGHFORD
which vacume lines are you refering to?
Old Nov 25, 2009 | 08:36 AM
rla2005's Avatar
rla2005
All of the plastic vacuum lines that run around the engine compartment. Spraying with carb cleaner is not really going to tell you much, IMHO.
I used a hand held vacuum pump/gauge to test each vacuum line/circuit/component on my '92 F350. I disconnected each one, tried pulling a vacuum, when it failed I replaced lines/components until it did hold a vacuum, then moved to the next.
chuck7300
Jul 18, 2014 05:07 AM
backdraft341
Jul 16, 2010 04:20 PM
ray5484
Sep 24, 2004 09:44 AM
akmud
43
Mar 5, 2004 01:34 PM
