1986 Vacum Problem
Old Jul 16, 2010 | 11:44 AM
backdraft341's Avatar
backdraft341
1986 Vacum Problem
i have a 1986 f150 with 302 fuel injected auto trans. whats the best way to check for vacum leaks? with the truck running i cant hear anything. i have a rough idle. but runs fine while driving. thats why i think its a vacum leak. what about the mechanic stethiscope? i have a vacum guage is there a place to hook in to let me know if there is a leak somewhere? thanks
Old Jul 16, 2010 | 04:20 PM
Franklin2's Avatar
Franklin2
Some people take a propane torch, open the valve a little bit, but don't light it. If the propane gets sucked into the engine, it will make it idle faster.
Someone might have a safer way, but most anything you spray or use will be volatile so the engine will burn it, so be careful.
8lug
Aug 26, 2012 12:14 PM
ElwoodMurphy
Nebraska Chapter
Sep 18, 2008 02:06 PM
Talyn
Michigan Chapter
Aug 11, 2007 09:45 AM
kman2785
Dec 13, 2002 12:44 AM
