engine running cool ?'s
Old Nov 24, 2009 | 05:25 PM
kadrocker's Avatar
kadrocker
Other than my thermostat sticking, what else can make an engine run cool?
I changed my heater core the other day and now my engine runs cool.
This morning my truck got up to operating temperature and was blowing nice warm air.
This evening my truck never got up operating temp and it was blowing cooler air than this morning. (it did this the days ago as well)
I don't think my gauge is faulty. Sometimes it runs cool, other times right where it should it. Think my thermostat is starting to go? I'm gonna get a replacement tomorrow afternoon before I have to drive the truck again on Friday.
Whatcha think guys?
Old Nov 24, 2009 | 06:02 PM
brooklyn's Avatar
brooklyn
maybe the new heater core just works really, really well and you'll need to replace your thermostat with one that has a higher temp rating for the winter?
other than that, all i can think is timing too advanced; but i think that would be more predictable- slightly low, all the time. i'm still learning about timing, though, so don't count on my thoughts alone.
frankly, i wish i had your problem.
Old Nov 24, 2009 | 09:23 PM
fmc400's Avatar
fmc400
MSEE
The stock electrical gauge is useless. It's not meant for quantitative diagnosis; it's simply meant as a go/no-go warning tool. To truly diagnose this problem, you need to install an aftermarket mechanical gauge that actually displays the temperature of the coolant (in numbers). You can't use terms like "in between the O and the R in 'NORMAL'" to diagnose a temperature problem.
Old Nov 24, 2009 | 09:59 PM
75F350's Avatar
75F350
How far do you drive to get the engine up to operating temps? If it is simply taking longer for this to occur, it may indicate a t-stat that will not close all the way, and the liquid cant reach operating temps during the short time you are driving.
If it sits and idles, will it come up to temp and blow hot air?
I too believe that this is t-stat related, but you will have to know just how hot the engine is actually getting to diagnose further.
Old Nov 24, 2009 | 10:57 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
How low is your coolant?
Josh
Old Nov 24, 2009 | 11:09 PM
vtjvt's Avatar
vtjvt
had the same problem when I first bought mine, I put a new 180deg t-stat in and problem is gone.
Old Nov 25, 2009 | 12:47 AM
Kennewick's Avatar
Kennewick
A 190 is better. At 190 there is less engine wear on the rings and cylinder walls.
Old Nov 25, 2009 | 09:07 AM
fmc400's Avatar
fmc400
MSEE
Agreed. I wouldn't go below 190. 192-195 is optimal.
Old Nov 25, 2009 | 11:03 AM
jimlj's Avatar
jimlj
Josh
That is my first thought. Check you radiator and fill if necessary before you buy a thermostat
Old Nov 25, 2009 | 11:24 AM
kadrocker's Avatar
kadrocker
Coolant level is good. Checked it after the heater core swap and after it had circulated through the system. I had to add some water to top it off.
It is probably three-fouths water as of right now- I wanna put 50/50 in here before it starts getting cold and freezing.
Old Nov 25, 2009 | 11:32 AM
peganit2's Avatar
peganit2
Is it just me or are aftermarket thermostats not as good as they used to be?!?!
I replaced the OEM one in my Aerostar about a year ago and I just had to change it again about a month ago. I've actaully never seen one that was stuck like that one was stuck. I've only replaced them till now as a precautionary measure.
Are these trucks tricky to get coolant into the heater core? My Aerostar is. I have to jack the front of it up as high as I can to get the HC to fill.
Old Nov 25, 2009 | 06:16 PM
Bullitt390's Avatar
Bullitt390
There is definately a quality control problem with parts store t-stats.
I had a 195 t-stat in my truck barely last 3 weeks before it gave up. The one in my truck now has gone bad, almost made it a year with this one... so it will be 3 t-stats in about a year for me, with barely 5000 miles in that time.
I've never had a problem with filling the system on the Truck. Just drained it to do whatever, then re-filled as much as I could, start the engine and let it get hot, then top off. Might have to top off once a little later, but that is basically it.
Josh
Old Nov 25, 2009 | 06:22 PM
Bullitt390's Avatar
Bullitt390
Double post
Old Nov 25, 2009 | 06:23 PM
dkf's Avatar
dkf
Probably crap foreign thermostats. I ordered a t-stat from summit since I ordered so other stuff and got a Mr.Gasket t-stat and it was made in china.
Old Nov 25, 2009 | 06:27 PM
Bullitt390's Avatar
Bullitt390
Stupid triple posting
