I know it's probably a stupid question but here goes.
Does the front exit of the MC supplies pressure to the front wheels and the back exit to the back wheels?
Is it the other way around?
I need to know because I will bypass the 4WABS module that is shot and leaking, I have the ABS fuse removed and the system disable for years anyways (I refuse to let a computer take control of my braking).
I know that for some people, bypassing the ABS maybe a taboo subject but I'm a grown man, I take full responsability
Normally the rear outlet supplies the front brakes. Just to be sure for your truck look into the master cyl resevoir and see where the division is between front and rear parts of the resevoir. The outlet below the bigger part of the resevoir goes to the front brakes.
I don't really see inside the reservoir since it's the kind with a round cap and a floating thingie inside.
