1978 - 1996 Big Bronco
Some bad luck....
Old Nov 24, 2009 | 04:56 PM
RyanAmarias's Avatar
RyanAmarias
Some bad luck....
Well I had the rear axle rebuilt with all new bearings and limited slip plates as well, axles has very minimal pitting and ring and pinion looked good. I then start getting a vibration coming from the drive shaft. I have a driveline shop refurb the entire shaft, new u joints all that. I then go for a ride and get on it a little from a dead stop and It goes and POW... I have no forward gears, drive shaft is fine, I have reverse and it works fine. It was cool reversing down one way streets in Dana Point to a safe parking spot. Tranny has plenty of fluid, it just revs up in d 2nd and low. I put two quarts of fluid and when I shift from d to low it feels to kick in but still just revs. Transfer case? Tranny? More money? Yes.
1989 Ford Bronco Xlt
5.8 C6
Old Nov 24, 2009 | 05:12 PM
Kemicalburns's Avatar
Kemicalburns
check your vacum modulator, but sounds like you may have lost the tranny. lets hope not
Old Nov 24, 2009 | 07:21 PM
g_k50's Avatar
g_k50
You lost me at "and get on it a little from a dead stop"
Old Nov 24, 2009 | 08:31 PM
Biggiebronco92's Avatar
Biggiebronco92
get on it a little from a dead stop.... like taking off quick from a stop sign...
sounds like a tranny gone again..
Old Nov 24, 2009 | 09:18 PM
RyanAmarias
G_k50, You have amazing feedback on most of the posts you make. Thanks for the help.
Old Nov 24, 2009 | 10:31 PM
greystreak92's Avatar
greystreak92
If you can't take sarcasm, leave it alone. Can the vulgar responses.
Old Nov 25, 2009 | 10:45 AM
northeaster79's Avatar
northeaster79
it does sound like your tranny may have gone,might not hurt to pull the pan and check the filter,maybe toss a new one in it along with some fresh fluid and see where you stand after that.
what vulgar responses?
Old Nov 25, 2009 | 10:48 AM
Kemicalburns
like i said check the easy things first. look at the vacum lines going to your modulator. or the modulator crapped out and needs replaced.
Old Nov 25, 2009 | 11:11 AM
northeaster79
kemicalburns,I may be wrong about this and not trying to argue
but if the modulator was gone wouldn't it just stick in low gear,or shift right into drive?I'm no expert when it comes to auto trannies just throwing that out there,I have seen the filters collapse and cause the loss of one or both directions in a trans before.
Old Nov 25, 2009 | 01:48 PM
Kemicalburns
you could be right. although if he has lost a vacum line to it or its leaking will cause issues. All i am saying mainly here is to check the cheap stuff first.
Old Nov 25, 2009 | 05:41 PM
RyanAmarias
I'll check out the modulator and probably drop the pan tomorrow... One of these might be in my future though...
http://www.bmracing.com/PRODUCTS/Ford-C-6
Old Nov 25, 2009 | 08:55 PM
northeaster79
hey kemicalburns,I'm all about keeping it simpe and cheap,mainly cheap!!!!
but even if the modulator is toasted it would still have forward gears,just disfunctional ones,as much as I hate to say it,odds are the tranny is done.
Old Nov 25, 2009 | 09:02 PM
g_k50's Avatar
g_k50
New C-6? Might as well go with one of these too==>Ford Racing Performance Parts []
Old Nov 25, 2009 | 09:05 PM
northeaster79
hey we all got an extra 8k kicking around to dump on a 3k truck.
Old Nov 26, 2009 | 12:42 AM
RyanAmarias
I might have some problems smogging that baby here in Ca.
