Max towing capacity
Old Nov 23, 2009 | 01:28 PM
frederic.c01's Avatar
frederic.c01
Talking Max towing capacity
hi all
can you give me Max towing capacity for my f350 dually 7.3l idi turbo/4.10
my gvwr is 10000 lbs and i want tow proler regal 305rlds gvwr 11600 and dry weight 9057 ,can you tell me if is possible.it's very difficult to find something about us fifth wheel and truck in france so i need help.
and can you tell me what fifth wheel hitch must i buy .
thank's for all
fred
Old Nov 23, 2009 | 03:10 PM
84 f250 6.9's Avatar
84 f250 6.9
it will pull it no problems you honestly could probably add a couple more thousand lbs lol
Old Nov 23, 2009 | 03:51 PM
LCAM-01XA's Avatar
LCAM-01XA
Is your transmission an automatic? If yes then your GCWV is 17000 lbs IIRC. Your truck being a crew-cab it will likely weigh about 7000 lbs alone, which leaves you with 10000 lbs for the trailer. So yes, you should be able to pull that Prowler no problem.
Which 5th wheel hitch you need, well that depends on what you can get in France, but for safety reasons I'd go with something rated at 15000 lbs.
Old Nov 23, 2009 | 07:58 PM
PLC7.3's Avatar
PLC7.3
This is right from the Ford Recreational vehicle and trailer towing guide 1992-3....
The GCWR of the Fseries trucks towing a frame hitched trailer.
F series with 7.3 and automatic is:
355....12000lbs
410....17000lbs
F series with 7.3 and manual is:
355....12000lbs
410....14000lbs
The CGWR of the Fseries trucks towing a Fifth wheel trailer.
F series with 7.3 automatic is:
355....12000lbs
410....17000lbs
513....18000lbs
Fseries with 7.3 and manual is:
355....12000lbs
410....14000lbs
513....17000lbs
Old Nov 23, 2009 | 09:40 PM
cornking's Avatar
cornking
Remember to have a working brake controller and the trailers brakes checked out. You don't want to get pushed through and intersection while trying to stop.
Old Nov 23, 2009 | 10:22 PM
timothyr's Avatar
timothyr
anyone know why the weights are lower for a manual vs a slushbox?
Old Nov 24, 2009 | 12:22 AM
frederic.c01
thank you for your answers, that helped me a lot.
I have an airstream land yacht 1973 and I wanted more space that is why I changed.
Do you think i must add a big deep pan +4qt and with my airstream (5200 lbs ) i towing with od do you think i can with fifth wheel on flat road.
Old Nov 24, 2009 | 05:05 AM
LCAM-01XA's Avatar
LCAM-01XA
Yes you can tow in OD on flat road, the transmission is plenty strong for that. Big pan should not be needed, it's a nice thing to have but not entirely necessary. What is necessary, however, is a big external cooler for the trans, as the E4ODs tend to make lots of heat when the converter is not locked.
AlZipp
All Things Towing
16
Jul 3, 2017 03:25 PM
EricRom
6.7L Power Stroke Diesel
32
Sep 25, 2016 10:27 AM
towm8ter
All Things Towing
23
Jul 28, 2016 09:45 PM
SwensonBarrettBunch
Jul 23, 2016 01:31 PM
mc
19
Jul 17, 2011 03:18 PM
