Sponsored by: Real Truck
Transfer Case
Old Nov 23, 2009 | 07:52 AM
1ford1's Avatar
1ford1
Transfer Case
I bought a 99 Superduty. There is a tube on top of the transfer case with nothing connected to it. Is this a vent? Should I connect a rubber hose to it? Also, there are only two bolts connecting the transfer case to the tranny. I know there should be more bolts, the open holes are there. Are they all the same size and if so, what is the size? Thank you
Old Nov 24, 2009 | 08:16 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
I think that vent should at least have a hose on it, run up to the frame, and then looped down so it can't fill with water.
As for the bolts, I have no idea, but support the transfer case with a jack, remove one, and match it up at the parts store
Weird that the bolts are missing.
Old Nov 24, 2009 | 08:51 PM
1ford1's Avatar
1ford1
Thank you. I had concern the bolts may be different lengths. I stopped by a tranny shop and found out the bolts should all be the same. I forgot to ask about the tube. I plan to put a piece of hose on it. Thanks again
Old Nov 25, 2009 | 12:39 PM
krewat's Avatar
krewat
Well, a depth gauge would tell you if the holes are all the same depth. A dial caliper usually has a piece that sticks out when you open them up, that's the depth gauge.
If it was an open hole, you'd have lots of fluid pouring out
Lobuck76
Feb 23, 2006 12:11 AM
wge
Aerostar
Dec 9, 2003 03:08 PM
bearfoot_25
Jul 11, 2003 12:37 AM
50yellowbeast
Mar 16, 2001 08:05 PM
