carburetor
Old Nov 23, 2009 | 01:27 AM
thachamp's Avatar
thachamp
carburetor
hey guys thank again for all the input on the shifting issue awhile back. for the update i did in fact install a floor shifter and yes has a few kinks but is getting the job done.
so my next issue is now with the carb. i was wondering if anyone had a diagram or walk thru for the stock carburetor. tonight i was finally able to drive my 65 custom cab home. everything was going good with minor issues. first the top butterfly keeps getting tuck and i wanted to know the remedy to get it to properly work. i can assume that it is mainly for the choke (i'm not to experienced with carbs so bare with me please :] ). also to top that the bar the hooks on at top of it i noticed that it was snapped off from the whole butterfly assembly. so i asked my friend about what he did exactly with the whole carb assembly. it seems he just took it off to clean it . so i was wondering if connected everything right. so to the second problem. as im driving i had to ease the throttle almost to the point of barely touching it because if i applied too much pressure the engine would just die. while this is going on i keep hearing a large popping sound ( like a lid of a pot blowing off from pressure), which i honestly feelits that top butterfly shutter.
can someone please help. would even buying a new carburetor be in order. if so where can i find a stock one ( not really looking for preformance). after driving this truck i feel i've found a new love and appreciation for this truck. and if anyone can help me understand this truck more it would be appreciated.
the most i can tell you its a 1965 f100 custom cab, automatic, with the 352 block ( so i've been told).
thank you again
oh to finish tonights adventure..... i ws going up a hill about a mile up from house and i hit the gut wrenching redlight. i begin to go and the engine died again. lucky for good friends with AAA right .
Old Nov 23, 2009 | 03:32 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
the most i can tell you its a 1965 f100 custom cab, automatic, with the 352 block.
The same 2V Auto-Lite/Motorcraft 2100 Series carb (manual choke) was used on 1963/64 292's; 1965/67 F100/350 352's; 1968/69 F100/350's w/360/390's; 1969 F100 302's.
The same 2V Auto-Lite/Motorcraft carburetor kit (D4AZ9A586A - Motorcraft CT499D) fits ALL 1962/74 Passenger Cars, 1962/74 F100/350's, 1966/74 Bronco's and 1969/74 Econolines.
Old Nov 23, 2009 | 09:01 AM
46yblock's Avatar
46yblock
I have a 2100 carb, manual choke, rebuilt last week. It has been tested on my 292 and works great, and is available. PM me.
Old Nov 23, 2009 | 09:02 AM
46yblock's Avatar
46yblock
Duplicate post.
Old Nov 23, 2009 | 10:43 AM
thachamp's Avatar
thachamp
ty for the help. i sent you a message 46yblock. and just wondering is there anywhere i can this 2100 series like from napa or pepboys?
Old Nov 23, 2009 | 11:44 AM
daveengelson's Avatar
daveengelson
If the truck has been setting for any length of time may try removing and cleaning with aerosol can of carb cleaner, inside and out, install and squirt couple shots in the inlet while it's running.
Posting couple links in event decide on a 'do it yourselfer'. Not familiar with the 2100 series but recently rebuild couple holleys. Found it best to designate a work area for the rebuild and make sure area is clean. I dissassemble and removed all components that could be damage by soaking in carb cleaner and let set overnight. If digital camera available may want to take couple pic's during disaasembly. When assembling, use air to clean out passages, be carefull don't want to launch a needle valve, spring, etc. If compressor is not available a can of compressed air, type used for cleaning computers, should work. Can't emphasis enough keeping area clean. Finally, compare price of rebuild kit, skill level to that of purchasing a rebuild.
http://www.therangerstation.com/tech..._2150_carb.pdf
Autolite 2100 Carburetor Rebuild
Old Nov 23, 2009 | 03:05 PM
thachamp's Avatar
thachamp
thanks man the links helped out visually a lot. exactly what i was looking for. now can i purchase these rebuild kits at local parts stores or are there certain places i need to check out?
Old Nov 23, 2009 | 05:08 PM
46yblock's Avatar
46yblock
A good local independent supplier, NAPA or Carquest should be able to fix you up. Last one cost me $28.
Old Dec 5, 2009 | 08:32 PM
thachamp's Avatar
thachamp
thanks again
hey guys thanks for all the input. so i did the rebuild i realized something. the screw the screws down the venturas, if im not mistaken, has a type of weight that goes in after you drop the metal ball in. well i checked and i was wondering what exactly does it do and i'm assuming the last owner didnt put it in. is there anywhere i can get a new one or find something that works the same? if not im still on the search for a new carburetor if anyone is getting rid one.
Old Dec 5, 2009 | 09:06 PM
billy12360's Avatar
billy12360
i went with napa today... 22 bucks...
and for a previous post the OP posted, it may be tricky to just order a stock carb through napa... i checked with them today... 260 dollars and 2 week wait... they couldnt find anything in their system for a 2100... (might check on a newer ford like bill said earlier i think 74 f-100) but they said they had to order it from a different company... so i will just rebuild it...
Old Dec 6, 2009 | 08:44 PM
46yblock's Avatar
46yblock
I dont know exactly what it does, but I have one for a 1.02 venturi and a 1.14 venturi 2100. It may put resistance on the ball so that emulsion tubes dont dump excess gas. Both weights are very similar but not exactly the same. PM me.
Old Dec 7, 2009 | 02:57 AM
NumberDummy
I'm still on the search for a new carburetor if anyone is getting rid of one.
How many would you like?
1965 F100/350 352 2V = As original:
C5TZ9510B or C5TZ9510M .. 2V Carburetor / Use with M/T / Obsolete
C5TZ9510C or C5TZ9510N .. 2V Carburetor / Use with A/T / Obsolete
In 1969, Ford replaced all of the above carburetors with:
C9UZ9510AA .. 2V Carburetor (Motorcraft CA698) / Obsolete
KINSEL L/M in Beaumont TX has ONE = 800-816-2894.
BOB ALLEN FORD in Overland Park KS has ONE = 800-676-0675.
PARTS INTERNATIONAL in Farmers Branch TX has ONE = 888-727-0418.
GREEN SALES CO. in Cincinnati OH has TEN = 800-543-4959.
No other Ford Dealer or obsolete parts vendor has any.
No Ford Dealer or obsolete parts vendor has C5TZ9510B, C5TZ9510M, C5TZ9510C, or C5TZ9510N.
NOTE: C9UZ9510AA also replaced all the 2V carbs used on 1966/67 F100/350 352's.
D4AZ9A586A .. 2V Auto-Lite/Motorcraft Carburetor Kit (Motorcraft CT499D) / Available from Ford.
MSRP: $33.42 // FTE Ford Dealer Parts Dept sponsor PARTSGUYED.COM price: $20.08.
Fits ALL: 1962/74 2V Auto-Lite/Motorcraft carburetors used in F100/350's, Bronco's, Econolines and Passenger Cars / D4AZ9A586A replaced C2AZ9A586B (Motorcraft CT499B).
Old Dec 7, 2009 | 06:30 PM
46yblock's Avatar
46yblock
Glad to hear you are doing it yourself. I watched my retired mechanic friend from beginning to end and he took 2 hours, with a labor charge of $40. Carb looked close to new and worked great. I am waiting for a 1.21 Mercury carb to arrive so I can start on it. Figure it will take 3 hours to do and I should be making close to 15.00 and hour.
Ebay has a lot of sellers of rebuilt 2100s. They are generally very good. Prices run from 120.00 to 160.00. Make sure you get the same size carb the truck came with, as they ranged from .098 venturi's all the way to 1.23. The FTE forum on carbs and FI has a sticky at top listing the sizes and their CFMs.
Old Dec 7, 2009 | 07:26 PM
NumberDummy
IMO, before spending 120-160 bucks for a rebuilt carb...that may not be worth 10 cents, call the sources I listed in post #12 to see what their asking price is for the BRAND NEW Genuine Ford carburetor.
Since the carburetor is obsolete, it can no longer be returned to Ford...which means the Dealers are STUCK with it.
Old Dec 7, 2009 | 07:56 PM
46yblock's Avatar
46yblock
It is always good to have options . IMHO, stay away from Pony Carbs. Their $450 price for a rebuild is rediculous.
