carburetor
okay cool that's exactly what i was thinking, well the process of it anyway. i came to that conclusion when after i did the rebuild,the carb worked a lot better. but the same problem kept happening where when i would step on the accelerator the engine would just die. when i checked the carb i would notice not only a strong smell of gas but i also would see a good amount of vapors. this lead me to think there was a flooding issue. so as of today i adjusted the accelerator rod to the other hole and now it seems better, i can actually rev the motor without it dying. but yet im still being cautious due to the fact i didnt drive test it yet because of the weather. i plan to test it tomorrow and will be sure to post the results. but honestly i would feel better just getting the little weight rod just because its meant to be there, i will try to find out the size of the venturis and contact you.
oh and thank you number dummy for the part references, ill be sure to keep close just in case.
