A question for you guys
Old Nov 22, 2009 | 04:47 PM
150ford's Avatar
150ford
Just curious about my keys. Im going to get a couple more spare keys for my truck. Does anybody know if my truck has a chip in the key itself. Ive talked to some an said yes they do an others do not. My truck is an 2003 7.3 Reg cab. Thanks for the help guys.
JOEL 2003 PSD Reg Cab
Old Nov 22, 2009 | 04:49 PM
monsterbaby's Avatar
monsterbaby
look at the top of the key and see if it looks like there is a spot you could pry out like an access point. If so then it has a chip in it. If the plastic is solid and no "access" point then no it doesn't.
Old Nov 22, 2009 | 04:55 PM
150ford's Avatar
150ford
How big off a deal is it to get new keys made if its chipped. Is it expensive. Thanks for the info Rob.
Old Nov 22, 2009 | 05:01 PM
indyF-350psd's Avatar
indyF-350psd
you can't fix stupid!
you shouldnt have a PATS key for your truck. you should be able to go to lowe's or wherever and get one cut for a couple bucks.......
i did however just have to get a PATS key made for my focus and it cost me 120 bucks at the dealer and that was just a plain jane key. my fusion has the key and fob all in one so i bet that one would run me somewhere near 300 to buy and program..........
Old Nov 22, 2009 | 05:31 PM
monsterbaby
If you have 2 keys already you don't need to have the dealer program the third. (as told to me by the dealer friday when they made an extra for my ranger) You DO however have to get the blank from Ford and it's about $25 for the blank. Anyone can cut it after that.
Here is an article on fte for doing it
PATS Key System Programming .: Articles
I found this one on a mustang forum that is a little more detailed. scroll down to method C for your truck
http://mustangforums.com/forum/4-6-m...-pats-key.html
Old Nov 22, 2009 | 05:36 PM
150ford's Avatar
150ford
I see it doesnt say anything about superduties having these chips. Maybe im in luck. Thanks for the help.
Old Nov 22, 2009 | 05:59 PM
monsterbaby
My 2000 doesn't.
Old Nov 22, 2009 | 07:00 PM
mxracer3276's Avatar
mxracer3276
FWIW, my 2003 does not have a chip in the key.
Old Nov 22, 2009 | 07:17 PM
Izzy351's Avatar
Izzy351
Only Ex's do, IIRC. They're not in SDs...
