Injection pump installation/priming
Old Nov 21, 2009 | 10:04 PM
Gknight's Avatar
Gknight
I have installed a rebuilt stanadyne injection pump. I have
the lines to the injectors loosened up, some
just sitting on top of the injector and have cranked and
cranked. I opened up the input line at the pump and have
plenty of fuel coming out there. I opened the return line
on top of the pump and some fuel, not like at input,
comes out there.Is there anything else I need to do to
speed up the flow. I recharged my batteries and am ready
to get at it again tomorrow.
Old Nov 21, 2009 | 10:10 PM
Links56's Avatar
Links56
It just takes forever because you didn't prefill your injector pump with diesel or ATF also be sure you don't let your starter get too hot. An alternative is to pull it around with another truck.
Old Nov 21, 2009 | 10:19 PM
7bicks's Avatar
7bicks
It really should not take that long. Verify that you FSS is working and hooked up properly or you will crank until the starter melts into a puddle without it starting.
Old Nov 21, 2009 | 10:22 PM
7bicks's Avatar
7bicks
I just did mine on Friday and it only took about 4 cycles of cranking and letting it cool.
Old Nov 21, 2009 | 10:56 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Make sure you have power to the fuel shut off solenoid when the key is on.
And then with the key on, pull the wire off the fuel shut off solenoid and touch it to the connector while listening closely.
You should be able to hear the solenoid clicking as you add and remove the power to the terminal.
Old Nov 22, 2009 | 12:51 AM
ford trans tech's Avatar
ford trans tech
some of the IP,s trap air in them and cannot purge it normally
i have experienced it several times over the years
take the fuel return line off at the top of the IP and crank it over till there is solid fuel coming from it
then reconnect the line and crank again till fuel is present at the injector lines
Old Nov 22, 2009 | 11:27 AM
Gknight's Avatar
Gknight
ford trans tech..I have opened the return line and had some fuel coming out. Will check it out
again.
Dave Sponaugle and 7bicks..the Fss has 12 volts to its plug. Dont know how to test the
switch itself.
Links 56..What is there to prefilling the injection pump. ?
Old Nov 22, 2009 | 12:24 PM
PLC7.3's Avatar
PLC7.3
Plug in and unplug the FSS a couple times you should hear a click...... I would connect all the lines and crank it over with only 1 or 2 loose. Crank starter for 20 seconds max with a 3 minute cool down between attempts. after the first hint of firing torque all injection nuts 20 ftlbs max. Having all the injector nuts open can allow air back into the system and drainoff.
Old Nov 22, 2009 | 04:16 PM
Gknight's Avatar
Gknight
I will un pluging and touching the plug to the FSS terminal. Dave Spronaugle told me how to do
this, but my memory isn't too good. Thats no excuse though, he resent the picture with that on
the bottom of it. I will try that and if I hear the clicking, I will loosen a couple of the injector caps
and crank over some more. Thanks.
Old Nov 22, 2009 | 06:50 PM
Gknight's Avatar
Gknight
I do have 12 volts at the FSS plug and it does click. I have tightened down all of the injector caps
but two and it will sit like that till tomorrow afternoon sometime I guess. It's rained off and on
most of the day and is raining now and this is a shade tree job. I will get back on after I've
had time to work with it some more and let you know what's happening.
ALL-SEASON'S
16
Feb 15, 2019 10:59 AM
dyoungen
Nov 27, 2014 04:25 PM
countrycar
Nov 21, 2012 07:16 PM
McQ
Jun 22, 2012 07:20 PM
