Transmission Leak
Old Nov 21, 2009 | 09:22 PM
bigdaddys99's Avatar
bigdaddys99
Transmission Leak
Hey guys! I love these forums! Most of my question gets answered by searching the forums but now i got this issue.
I have a late 99 psd f250 auto trans with 170k. Original transmission still good till now. I bought this truck 6 months ago never had i leak till a month ago. It started leaking from the front seal that the tq converter goes into.... so i thought....so i replaced that front seal and the dang thing still leaks. I know for a fact that we put that seal in right, so what else could cause that fluid to come out that front seal??? is it the pump and seals or something else??? I cant see it being that front seal again cause i know we did that right.
Once we got the trans out and tq there was no fluid round the pump just in the middle bottom of that seal fluid was coming out.
Please help fellow psd owners!!!
ps forgot to add that this was a work truck for a steel company and it has a 5th wheel hitch and i know they towed the crap out of it.
Old Nov 22, 2009 | 12:23 AM
agg_bagg's Avatar
agg_bagg
here is a bump for ya bob.....
and i am subscribing.....
Old Nov 22, 2009 | 06:37 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
How was the bushing that the torque converter rides on? Often when the seal leaks it's because the bushing is worn out. It could also be a rough surface on the torque converter hub.
Old Nov 22, 2009 | 06:45 AM
nissandoc's Avatar
nissandoc
I had one at work about a month ago, it was a gasser van, that i thought the the pump seal was leaking. It turned out to be the o-ring around the pump. There is also a paper gasket that you would need to replace as well if you pull the pump.
Old Nov 22, 2009 | 11:29 AM
bigdaddys99
I did not notice that there is a bushing on there. I guess all there is to do is pull it back off and check everything.
Thanks for the input
Old Nov 22, 2009 | 11:35 AM
bigdaddys99
Where can i find detail pictures or a diagram or something for the transmission so i can see what im looking for.
Old Nov 22, 2009 | 12:15 PM
agg_bagg's Avatar
agg_bagg
bob i have some pics in the rebuild manual
Old Nov 22, 2009 | 01:03 PM
bigdaddys99
Well i need to come get that manual from you then dude.
also with the leaks starting now is this a good indication that the tranny is about to have serious problems???
Could the pump or something else cause the pressure to shoot out the front??? other then just seals going bad...
Old Nov 22, 2009 | 08:50 PM
bigdaddys99
Bump
So i decided that im going to pull the transmission and replace the pump seals and bushing. Just want to know exactly what seals i would need and possibly other stuff i should replace while its out.
Thanks
bob
Old Nov 23, 2009 | 08:48 AM
agg_bagg's Avatar
agg_bagg
here is another bump for you bob
Old Nov 23, 2009 | 09:39 AM
RedBoat's Avatar
RedBoat
Rather Be Floatin
Bob, I had 101k when my torque converter seal had to be replaced because it was leaking. The shop I used had to replace the bushing, the old bushing was worn out. Mark is right on with his advice!!
tom6433
Oct 22, 2014 11:38 AM
BlkBoostedV6
Sep 1, 2013 07:37 AM
greenwoodford
Jul 6, 2013 09:34 AM
jrudnicki
Nov 6, 2012 05:02 PM
