Early 99 questions
Old Nov 21, 2009 | 07:21 AM
convincor's Avatar
convincor
Early 99 questions
Unfortunatly someone pulled out in front of me the other night. My bumper went over there hood and the tire/axle took the brunt of the impact..
The not sure if the housing is bent but the pinion gear is snapped off just inside the seal.. Repair shop say's the would just replace the whole axle with a good used.. My question would be what is the difference with the early/later 99 front end?? Same for the leaf springs. anyone know what was different?
more pics here- 1999 superduty pictures by convincor - Photobucket
Old Nov 21, 2009 | 07:37 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
That'll buff right out.
Seriously, damn dude that really sucks. The Sable is about a loss. I hate to hear of people getting hit or pulled-out-in-front-of. In all honesty, I'm surprised that the differential pinion shaft broke instead of the transfer case housing.
I sure hope you're not feeling too banged-up today since that had to hurt.
I'm no expert but that looks to me like a simple parts replacement candidate. Axle tubes are not very strong and they do bend quite easily. I'd call it junk since it's likely bent bad enough to cause spline wear on the side gears. It would be align-able but the damage you can't see makes all-out replacement a better idea.
As far as differences go between the E99 and 99.5-up front axles go, the brake rotors and hub bearings are different. It's going to be a D50 and you'll have issues finding a D60 in an F-250 up until '02. Some had them, but most had D50s.
Replace the front springs (and hangers), the steering box (since the sector shaft is snapped off), the front driveshaft because it's likely to be bent too, and the bumper, bumper brackets, and the fender(s).
Good luck getting it up and running quickly.
Old Nov 21, 2009 | 04:15 PM
convincor's Avatar
convincor
so as long as I know what year is being used for future parts purchase I should be ok. correct
Old Nov 21, 2009 | 06:33 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
As long as you find the front end out of your donor truck you will have everything you need to make the swap. You can use anything from 99-04, and it doesn't matter if it is D50 or D60. If you need some new stuff I have a D50 out of my Early 99 if you need it. Let me know.
Old Nov 21, 2009 | 09:24 PM
convincor's Avatar
convincor
good, that will make it easier.
i'll know more on monday once it starts getting torn down..
Thanks
Old Nov 23, 2009 | 08:08 PM
spunks00's Avatar
spunks00
What about the track bar...i am about to buy a used front axel to convert to 4.30 gears, wont you have to change the track bar? or bolt or somthing?
Old Nov 23, 2009 | 08:18 PM
jasonch's Avatar
jasonch
ouch, sorry out your luck there
Old Nov 24, 2009 | 10:24 AM
superduty4x4's Avatar
superduty4x4
Yes, and the bracket on the frame is needed as well.
Leeet
Oct 1, 2015 08:32 AM
49 Ford F-1
Dec 8, 2011 10:02 PM
virtualbong
1983 - 2012 Ranger & B-Series
Oct 19, 2010 12:27 PM
erbilabuc
33
Sep 7, 2010 09:32 PM
convincor
Jan 25, 2009 11:37 AM
