Hello, I am trying to see if anyone might know the problem I am having. I went to start my pickup this morning and it won't start. It's a 2002 F-350. When I turn the key it sounds like a drill. Yesterday I started it and there was a squeeky sound which I thought was the belt, but then when it wouldn't start this morning I don't know. I called Ford and they told me to bring it up there to look at it, but I have no way right now to get it up there. I just thought I could get a better idea of what it was. Thanks.
Starter mounting bolts loose?
Not uncommon for these trucks,could sound like a drill when turning and not engaging the ring gear.
Or the solenoid is going out and the starter is just spinning. Try giving the starter a couple of taps with a hammer and see if it will let it engage the flywheel.
Thank you for the reply. I will check that option.
Welcome to FTE.You will be better off listening to these un-official Ford technicians on here.They do not make aliving working on PSD's but their knowledge together is unlimited
Thank you everyone for helping me fix the problem. It was the solenoid which I found out from help from you guys. I fixed the problem last night and good to go. Thanks for saving me some money. I appreciate your help.
Welcome to FTE.
Thanks for coming back here and letting us know what the problem was. Don't be afraid to ask questions here. Good job.
