Steering Problems
Old Nov 21, 2009 | 01:55 AM
sbechtel101's Avatar
sbechtel101
Steering Problems
I have a 72 F100 4x4 with power steering. It turns to the left with no problem but will hardly turn to the right at all. I've spent hours under the truck looking for things that might be out of place but I don't have an extensive knowledge of what I'm looking at. I'm only a descent mechanic. I think I've narrowed it down to the steering gear box itself. All the linkages seem to be in tact. The stablizer that runs from the frame to the front axle housing only has one bolt in it and gives quite a bit when trying to turn. Could that be my problem?
Old Nov 22, 2009 | 04:28 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The P/S has been swapped in from another vehicle, as no 4WD was available with P/S until 1973.
1973/76 F100 4WD's used Power Assist P/S. There is a P/S control valve and ram cylinder, the manual gearbox is used, as it has nothing to do with the P/S.
Old Nov 22, 2009 | 08:02 PM
sbechtel101
I knew that. It's been swapped with a 79 year model power steering. I think the pump is actually from an early 80's model. I replaced the steering box and the nut and bolt on the bracket for the steering stablizer arm. Nothing worked. The truck still won't turn to the right. I'm going to try to jack the front end up and remove the pitman arm and change the position on it. Maybe that will work.
Old Nov 24, 2009 | 11:46 AM
jhooch's Avatar
jhooch
You say it doesn't turn to the right. Does it turn way too far to the left? If it does, re-indexing the pitman arm may fix it. If turning to the left is normal, could be another issue. Is it lifted? Could possibly need a longer draglink.
Old Nov 24, 2009 | 06:50 PM
sbechtel101
Yea it's lifted. It turns so far to the left that the tires rub the frame. I'm going to try the pitman arm and see what that does. I'm thinking that could be where my problem is. It seems to turn way far to the left but just a little to the right and then the pump starts screaming like it's bottomed out the worm gear in the box. If there's anything else it could be please don't be shy. let me know. I'm almost at the end of the line with it.
Old Nov 24, 2009 | 11:34 PM
jhooch's Avatar
jhooch
If the pitman arm is stock, I would switch to a drop pitman arm also.
Old Nov 25, 2009 | 04:18 PM
sbechtel101
That's a good idea. I had planned on doing that anyway as soon as funds were available but even though it's not hitting the frame and clears it both ways i think i may just go ahead and do that.
Old Feb 20, 2012 | 08:40 PM
dbdbb's Avatar
dbdbb
never mind
Old Feb 20, 2012 | 09:23 PM
mblayton's Avatar
mblayton
Disconnect the pitman arm and rotate the box via the steering wheel (count the turns) could be 2 1/2 one way, center the shaft and re-connect the pitman arm.
Old Feb 21, 2012 | 08:48 AM
69SCJ's Avatar
69SCJ
Did this start once you did the conversion? If so, Ditto what mblayton says. If it just started doing this on its own then something else it he problem.
Would you mind positn pics of the 79 box in your f100?
I'm tempted to do the mod Nod has as an article on this site, but am thinking of leaving the pitman forward rather than turning it to the rear. I'm curious how yours is set up. Also, is the box mounted directly to the frame or is there a spacer/plate added?
Thanks,
Tyler
mfhull
May 4, 2021 10:43 AM
johnhammond
Feb 17, 2017 05:42 AM
slus
Jun 15, 2015 10:59 PM
Dgpz1100
Jan 18, 2015 01:57 PM
SproutW
1978 - 1996 Big Bronco
Feb 22, 2005 06:15 PM
