DT466 Injectors
Old Nov 21, 2009 | 02:45 AM
PwerStroke99's Avatar
PwerStroke99
Originally Posted by Riffraff Performance
Do you plan on upgrading the turbo, getting custom programming etc? Because that is way more fuel than you need unless you plan on going BIG. There are a couple guys that come to mind like PowerstrokeJunkie and Strokin that both have big injectors in the 250cc-300cc and they could help you with the real life experience on these.
Clay, Superdoodie and myself also run the 250cc Hybrids from Casserly. These injectors are awesome!!! Absolutely awesome and as Joe said, they make the truck run like a raped ape.
Old Nov 21, 2009 | 08:14 AM
origcharger's Avatar
origcharger
In hopes to clarify some confusion or add to it, in the middle 90s International had a mechanical injection; DT466 PLN (pump, line, nozzle) engine and a HEUI DT466E engine. After that series of engines became history, around 2000 or so, they were all then HEUI, so they dropped the "E" designation and went back to calling them DT466s.
Also the 1994 and newer DT466s have four valve heads and don't even have the same bore and stroke as the older agricultural based engines. Its a completely differant design.
Old Nov 21, 2009 | 08:28 AM
DieselE's Avatar
DieselE
Pwerstroke99, how does it run with those injectors and factory hpop, bb charger helps im sure, but thats a lot of fuel huh..
Old Nov 21, 2009 | 08:34 AM
Izzy351's Avatar
Izzy351
Originally Posted by OTTOMATIC
They feel great. A BIG IMPROVEMENT especially with Beans Diesel Performance - 7.3 Power Stroke IDM Modification (Powered by CubeCart)
the improvement was so dramatic I had to put my PPE Standard in the DMAX to Level 3 so it would "feel " faster. LOL
Good deal, man. Been on a mileage run yet?
Old Nov 21, 2009 | 08:56 AM
sneak's Avatar
sneak
Originally Posted by DieselE
Im pullin the motor out this weekend to do injector cups, i got fuel in my coolant....yeah that sucks, gonna do injector o rings, put a new oil pan on, rear main seal, turbo o rings, and a few other little things
I just wanted to know why you're replacing your rear main?
Old Nov 21, 2009 | 02:42 PM
rbaker6336's Avatar
rbaker6336
Originally Posted by origcharger
In hopes to clarify some confusion or add to it, in the middle 90s International had a mechanical injection; DT466 PLN (pump, line, nozzle) engine .
DT466 came out in the '70s first as industrial the later in trucks
Old Nov 21, 2009 | 04:25 PM
origcharger
Yes but that version of the DT466s last year was 1993, it was a casuality of emission standards and was always mechanical injection.
1994 and newer are a completely differant engine, they don't even share the same bore and stroke as the earlier engines.
Old Nov 21, 2009 | 06:16 PM
rbaker6336's Avatar
rbaker6336
This is true,a reals shame the origonal version 466 had to go down.It was the most durable engine IH ever made
Old Nov 22, 2009 | 06:12 PM
DieselE's Avatar
DieselE
Sneak,
Just figured while it was out, would replace all the things that could cause me problems while it was out.. Gonna need an oil pan soon so im gonna put a new one on.
dtfreak89
66
Mar 11, 2017 05:42 AM
williameub
Dec 9, 2016 02:28 PM
trevorrules
Dec 13, 2014 09:41 AM
TheTowingCowboy
General Diesel Discussion
46
Dec 30, 2012 09:06 PM
scottie2hottie
56
Oct 3, 2011 06:28 PM
