04 explorer rear differential
Old Nov 20, 2009 | 04:42 PM
bigdan1979f-250's Avatar
bigdan1979f-250
I have a 2004 Explorer 4x4 V-6 and every now and then when backing up with the wheels turned, I can hear and feel a "pop". I know its not normal and was wondering if this was the limited slip, or if they even came with limited slip. I had a shop in town change the rear end oil and I specifically asked if it needed any additive for the differential and they said it did not have limited slip, but every time one of the rear tires starts to spin, I can feel what I think is the clutches engaging. Thanks
Old Nov 20, 2009 | 09:23 PM
steve(ill)'s Avatar
steve(ill)
my 2002 EXP is automatic 4 x 4. There is a computer that monitors each wheel and compares the speed. If one starts to slip, it puts more power to the others. Seems to work real good in the snow or when climbing a dirt hill. When we first got it, i did something and thought i had a BIG problem... Pulled off the side of road, cranked wheels real hard, then stomped on the throttle to do a quick U turn--- 4 tires turning 4 different speeds-- not good-- sounded like "clutchs locking up" as you said. Computer is thinking your stuck. See if thats whan you got. Been 4 years now. No problems, but i can make it do that on dry pavement in a quick U turn from a stop.
Old Nov 22, 2009 | 02:14 PM
bigdan1979f-250
Well that is a relief. Thanks for the input.
Old Nov 25, 2009 | 04:54 PM
fordmerc's Avatar
fordmerc
If your explorer has the tow package (2 inch receiver) then you have 3.73 gears with a limited slip. If you have the smaller receiver, you have 3.55 gears and no limited slip. Sounds to me like you need some friction modifier in your rear diff.
Old Nov 26, 2009 | 09:14 PM
robert11's Avatar
robert11
Look at the label on the drivers side door and if the axle code starts with a letter then its a limited slip. I think this is right, anyway you should be able to do a search and find out. I have a 2005 Sporttrac and my code is D2, 4.10 gears limited slip.
Old Nov 29, 2009 | 07:37 PM
steve(ill)'s Avatar
steve(ill)
conventional codes are normally 41- 42-43-45 etc. LS codes are D1 - D2 - D4..
Hunters
Oil & Lubrication
Feb 4, 2009 10:16 AM
Hunters
Feb 3, 2009 09:00 PM
rcjones
Offroad & 4x4
Jan 5, 2008 07:28 AM
BoVan
Mar 24, 2007 07:26 PM
djtdaveboy
1983 - 2012 Ranger & B-Series
26
Jun 4, 2004 01:06 PM
