High Idle Mod...Done
Old Nov 23, 2009 | 07:51 AM
Sarge261's Avatar
Sarge261
If you dont mind me asking where did you get it and about how much did it run you.
Sarge
Old Nov 23, 2009 | 07:57 AM
nitrogen's Avatar
nitrogen
as far as 1100 rpm cold idle i've spent the last couple years working with 1000hp cat/cumins/detroits, the base idle setting is right around 1100. they start em at1100,they shut em down at 1100 and the engine never seem to have issues. alot of the time i'll turn my idle switch on when i shutdown, the next morning i hit the command start, about 5 seconds after it fires up the revs crank up. i am running synthetic oil, now if i had frozen 15w40 that might be another story
Old Nov 23, 2009 | 08:17 AM
w_huisman's Avatar
w_huisman
Do you have a part number for the kit?
Old Nov 23, 2009 | 08:40 AM
PorchFarms's Avatar
PorchFarms
How do you tell if your truck has the gold package
Old Nov 23, 2009 | 10:39 AM
rotun's Avatar
rotun
Reads ***** rules!
It was $332.41 and purchased from the parts counter at my local dealer, definitely check prices as I found some had different prices. The part # for the security system is 7L3Z-19G364-AA, if you have a PATS key you will also need this part # 7L2Z-19G365-AA ($332.41 for both).
PorchFarms...if your key fob looks like the 1 I posted you have the gold package, "gold package" refers only to the rem. start/keyless entry/sec. system. They have a "silver" and a "bronze" package as well of which do not have all options, i.e. silver may have just security and keyless entry, bronze I think is just keyless entry.
Here is a link to Ford parts catalog online...
2007 Ford F-250 and F-350 Accessories
Old Nov 23, 2009 | 12:39 PM
GOT_DZL's Avatar
GOT_DZL
Says it only works on the 2007 and 2008 trucks, can anyone confirm if it works on earlier model years? (Gold remote start system)
Old Nov 23, 2009 | 03:56 PM
rotun's Avatar
rotun
Reads ***** rules!
I did put one on my 2003 F250 (7.3L) but it was a different part # of which I don't know what it is. They did change as the one on my '07 is different from the one in the 2003.
Old Nov 23, 2009 | 03:58 PM
rotun's Avatar
rotun
Reads ***** rules!
There are some respectable aftermarket remote start/ security systems available if you can't get the factory version.
Old Nov 23, 2009 | 04:33 PM
GOT_DZL's Avatar
GOT_DZL
Thanks for your reply, my truck is an '06 and it looks like Code changed the system in '07. But it looks like the Gold kit for an '06 is part # 2W7Z-19G364-AA
Reference: Remote Start with Keyless Entry and Vehicle Security 2W7Z-19G364-AA
Also just to be certain, you will only need the securi-lok addon if you have a PATS key, right?
Sorry for the derail!
Old Nov 23, 2009 | 05:25 PM
rocky1074's Avatar
rocky1074
If you check the site below 2W7Z19G364AA List $360.25 Cost $259.38
KIT REMO STR
Enter Part number; Vehicle Make; Search
https://www.trademotion.com/partloca...&siteid=215005
Old Nov 23, 2009 | 06:44 PM
rotun's Avatar
rotun
Reads ***** rules!
Yeah, the price I showed was for both the system and the PATS module with tax.
Old Nov 25, 2009 | 03:20 PM
88stang1's Avatar
88stang1
Originally Posted by Sarge261
The only problem with the PTO wire is if you are jumping somebody and your battery is weak then truck will not elevate any further to protect YOUR system. Yes its an instant jump...like 2-3 secs. after all criteria is met, but I usually have the A/C, heat, work lights running, or jumping someone...so the charge protect ckt. was a good choice for me.
Sarge
what colour is the charge protect wire
Old Nov 25, 2009 | 03:43 PM
  #28
69cj's Avatar
69cj
I don't want to hi jack the thread however, when I pulled the plastic cover off to access the upfitter switch wires there is a 14 pin white female connector, a 4 pin female connector and a 2 pin female connector just laying in there next to the fuse panel. Does anyone know what these are for?
Sarge261
Jan 17, 2012 03:53 PM
patrickdemart
Apr 6, 2011 01:16 PM
Sarge261
Jun 18, 2008 08:48 PM
Sarge261
Jun 15, 2008 08:09 PM
