High Idle Mod...Done
Old Nov 20, 2009 | 02:54 PM
Sarge261's Avatar
Sarge261
Hey there for all of you who havent done this it takes literally 10 minuites. I was puttin it off putiin it off puttin it off...for 3 years now LOL. After getting my truck back from service and a reflash recently I noticed on colder days the idle only goes up 100-200 rpm, not like before.
So if you have been procrastinating...like me, get er done.
Sarge
Old Nov 20, 2009 | 07:11 PM
juneau76's Avatar
juneau76
Put me on that list of procrastinaters. I need to coble in the upfitters so that I have a switch to use. Some day soon...
Old Nov 20, 2009 | 07:20 PM
Sarge261's Avatar
Sarge261
Hey Brad,
Happy Holidays to you and your family. I wasnt too worried about it until they reflashed it and it doenst idle up past 800 rpm anymore. Just make sure you use the charge protect wire.
Sarge
Old Nov 20, 2009 | 07:30 PM
MoyockPowerstroke's Avatar
MoyockPowerstroke
What does the latest Flash do for me? As for the upfitter switch items...you can order all thru FordPartGuy.com...much cheaper than going to the dealer.
Old Nov 20, 2009 | 07:57 PM
juneau76's Avatar
juneau76
Originally Posted by Sarge261
Hey Brad,
Happy Holidays to you and your family, also!
I already bought the upfitters from Ed; I just need to put them in.
Old Nov 20, 2009 | 09:20 PM
desertt5's Avatar
desertt5
I added the wire to my Ex, but still need to cut the hole to mount a switch. I really need to do this also.
Maybe I won't take 3 years, but then agian maybe........
Old Nov 20, 2009 | 09:29 PM
jorlee's Avatar
jorlee
I prefer the PTO wire for my elevated idle. It's a gradual rise to the elevated 1200 rpm than the bat charge protect wire. Where it's instantly at 1200rpm.
Old Nov 20, 2009 | 11:10 PM
nitrogen's Avatar
nitrogen
which ever wire you use just hook it to full time power, no switch. then anytime you're in park with park brake on it will rev up. i can't think of anytime i would meet those criteria and not want it on high idle
Old Nov 21, 2009 | 06:44 AM
Sarge261's Avatar
Sarge261
The only problem with the PTO wire is if you are jumping somebody and your battery is weak then truck will not elevate any further to protect YOUR system. Yes its an instant jump...like 2-3 secs. after all criteria is met, but I usually have the A/C, heat, work lights running, or jumping someone...so the charge protect ckt. was a good choice for me.
Sarge
Old Nov 21, 2009 | 05:36 PM
w_huisman's Avatar
w_huisman
I have it set up in my truck. I just leave the attached upfitter switch in the on position, and tap the e-brake whenever I want the hi-idle to kick in.
Works pretty sweet.
Old Nov 21, 2009 | 05:53 PM
69cj's Avatar
69cj
Sarge
SARGE, That's what viagra is for!
Old Nov 21, 2009 | 11:59 PM
Thor80's Avatar
Thor80
I also hooked mine up with the orange PTO wire but after reading this can anyone explain the advantage of using the charge protect circuit? Would you jump someone while using the high idle? I dont think I would think of doing that, just jump them while at a normal idle. Or maybe by using the charge protect circuit it activates it when you use it as high idle where as if you dont its not active at all? Any further explanation would be appreciated!
-Torsten
P.S. What color wire is it for the '05?
Old Nov 22, 2009 | 12:48 AM
rotun's Avatar
rotun
Reads ***** rules!
Sorry to inform you of this..................you're not done with the hi-idle mod yet! You will end up putting in the factory "gold package" (remote keyless entry/ security system) and wiring the hi-idle to the 2nd aux. output of the "gold package" so that you can remote start and remote hi-idle on those cold NY mornings!
Old Nov 22, 2009 | 05:01 PM
Sarge261's Avatar
Sarge261
When I jump start someone, wich I dont like to do, I always try to get someone to elevate the idle some. Now I dont have to. Also if for some reason there is too much draw , by using the charge protect circuit, it will vary the idle depending on the demand of the charging system. The PTO is a gradual rpm climb and will max at 1100, where as the CPC will start at 1100, and vary depending on charging system requirements up til 2200 or 2400 rpm max. The only down fall I can see is that the engine will run at 1100 rpm when cold...if someone could answer me is that hurting anything?
I always worry about installing the car starter on a diesel. How hard is it to install the Ford security/starter. Does it incorporate the existing key fob that comes with the security group, if forgot the option code and my buildsheet is at the shop.
So for now its complete....
Sarge
Old Nov 22, 2009 | 09:22 PM
rotun's Avatar
rotun
Reads ***** rules!
It has a timer delay for the diesels, being a factory product it comes with 2 new key fobs. As far as installing it...I asked the dealer who does their installs and called them, for $120 they came to me and did the install which wasn't difficult at all but it could be an all day job if you have never done one before. Just be sure to get the programming instructions as they do not come with the kit, I think I have it on PDF if you go the distance. Also, had it for 2 years now and not 1 issue with it.
