2006 f150 abs
Old Nov 20, 2009 | 06:26 AM
zigt06f150's Avatar
zigt06f150
2006 f150 abs
Looking for help
I have a 2006 f150 with 28000 miles on it. The ABS system is having problems. I was wondering if any one else is having issues. I had a sensor replaced on the rear and need to get the module replaced. The truck has not been abused. Any help would be great.
Old Jul 29, 2016 | 11:37 AM
Haines25's Avatar
Haines25
What module are you talking about? Where is it located? I have replaced rear sensor and both front sensors. The abs light is still on.
Old Jul 29, 2016 | 07:57 PM
brokenleg's Avatar
brokenleg
What does the codes say? just replacing parts isnt going to fix it.
Old Jul 29, 2016 | 09:58 PM
steve(ill)'s Avatar
steve(ill)
when you start the truck or turn the key to "ON" the ABS runs something similar to a continuity test to see that all the wires and sensors are connected and not broke. The light goes out in 3 seconds if all is OK... Now you start moving. Once you get above 5 mph the ABS runs another check to see if it sees speed signals from all sensors and they look similar in value... If not, the light comes back on meaning ONE of the sensors has bad output.. With the correct reader you can also get the CODE and know exactly what is happening.
Old Aug 19, 2016 | 10:00 PM
FlyingAl's Avatar
FlyingAl
If it's a 2WD, you could have a broken tooth on the brake rotor. I had this problem and new rotors fixed it.
Old Aug 20, 2016 | 03:09 PM
77 1/2 F250's Avatar
77 1/2 F250
Opening post is from 2009, I really doubt that he is going to answer.
Old Aug 23, 2016 | 11:39 AM
FlyingAl's Avatar
FlyingAl
You are probably correct but my response may help someone else.
woundedknee
2015 - 2020 F150
Jun 17, 2017 12:27 PM
Ray West
Mar 8, 2017 07:39 PM
06pghescape
Escape & Escape Hybrid
Jan 7, 2017 06:51 AM
Jimmy Krizan
Jan 4, 2017 07:45 PM
mgermany
Jun 30, 2016 08:14 AM
