P1316 code and vibration
Old Nov 19, 2009 | 08:29 AM
luny1's Avatar
luny1
I had the ses light come on yesterday and noticed the truck had a vibration.
I hooked up my predator programmer (I guess it is good for something).
"P1316 injector module code detected" Came up.
I searched around and I'm thinking its the under valve cover harness (uvch).
Is there one side that fails more than the other?
Any tricks or tips?
I saw this link:
https://www.ford-trucks.com/forums/9...nger-side.html
that was helpful.
Ron
Old Nov 19, 2009 | 08:36 AM
Kwikkordead's Avatar
Kwikkordead
There is no way of telling which side, you have to pull both covers.
While you are in there, be sure and retorque the rocker pedastals and injectors.
Old Nov 19, 2009 | 06:27 PM
F350-6's Avatar
F350-6
Often times you can use an ohm meter and figure out which valve cover needs to come off. Disconnect the flat 9 pin connector on the inboard side of each valve cover and test the pins looking for something out of spec.
The 9-pin plug is wired as follows:
G G I I C I I G G
G=Glow Plug +
I = Injector +
C= Injector Common
The injectors fire with a 115VDC signal from the IDM. Do Not pierce the wires to test.
Test between "I" and "C" to test the injectors, should be less than 5.0 Ohms.
To check glow plugs Test between "G" and battery ground. Should be less than 2.0 Ohms
If you find readings outside these numbers, pull that valve cover and check for the loose connector.
Old Nov 19, 2009 | 08:54 PM
dvskate's Avatar
dvskate
if one of the uvc harnesses were unplugged could the truck run?
Old Nov 20, 2009 | 12:18 AM
87 F-150 I6's Avatar
87 F-150 I6
The truck will still run, but it has a sever miss to it and no power. If you have AE, you can run a CC test and see what cylinders are not firing but you have a predator which I don't think can run that test.
Old Nov 20, 2009 | 01:53 AM
luny1's Avatar
luny1
Thanks for the info.
We pulled the passenger side valve cover and the plug was melted pretty bad.
Bought a new harness/gasket at Napa for $100.00.It came with a new plug that we soldered onto the trucks harness. Some of the bolts did need to be tightened.
We removed and checked each of the glow plugs. They ranged from .5 to .9 ohms.
(or was it 5.0 to 9.0?) I think the .9 was definitely on the high side,but I decided not to replace them.
We put the quarter in the harness and put it all back together. Runs much better.
We did not mess with the driver side.
Thank you for the help- Again! Ron
Old Nov 20, 2009 | 05:14 AM
WA.Ranger's Avatar
WA.Ranger
Glad you got her fixxed Ron! I freaked when my truck lost one side of the injectors after the light turned green on 99 and twenty and I romped on it to beat a semi.
Jesser02EX
15
Sep 13, 2013 01:51 PM
luny1
Dec 24, 2012 09:57 AM
luny1
May 20, 2010 07:30 PM
PlatinumPSD
Oct 4, 2007 08:09 AM
nissandoc
Mar 18, 2007 08:54 AM
