'55 fuel tank
Old Nov 19, 2009 | 12:04 AM
Daddyo's garage's Avatar
Daddyo's garage
'55 fuel tank
My pick up tube inside the tank has come un-soldered at the connector fitting at the top of the tank. Any ideas for a repair? Preferably a fire free solution!
Old Nov 19, 2009 | 08:00 PM
carnut122's Avatar
carnut122
A new tank?
Old Nov 19, 2009 | 08:21 PM
redsuperduty's Avatar
redsuperduty
Being at the top of the tank, I wouldn't be a bit afraid to use jb weld on it.
Old Nov 21, 2009 | 01:02 AM
Daddyo's garage
I did think of using epoxy but feared it may give up at a bad time and leave me walkin'. That would SUCK!
Old Nov 21, 2009 | 11:29 AM
Old F1's Avatar
Old F1
Works great!
Yep, it would!
Old Nov 21, 2009 | 12:11 PM
Daddyo's garage
OK guys, will epoxy or JB weld really do the trick. Sounds kinda like a bandaid. lol
Old Nov 21, 2009 | 07:49 PM
49fordpickumup's Avatar
49fordpickumup
Doesn't anyone weld on tanks anymore? I can remember guys filling them with water and weld away.chuck
Old Nov 21, 2009 | 09:04 PM
raerjim's Avatar
raerjim
I'm a fan of JB weld, but I would be hesitant to use it here. I would think liquid gas, ethanol, and hydrocarbon vapors would attack it 24/7, and it would leave you walkin at some point.
Old Nov 21, 2009 | 09:07 PM
Daddyo's garage
Yup! That's what I think. So unless someone has had success long term with JB weld, I think I'll try something else. Like drilling a hole and installing a new pick up tube.
Old Nov 21, 2009 | 10:58 PM
redsuperduty
Well, aside from soldering (which isn't fire free) or replacing the tank it was the best thing I could think of. I repaired my John Deere tank that was leaking at least 3 years ago with it and it's still holding, but who knows??
Old Nov 21, 2009 | 11:51 PM
Daddyo's garage
I seem to remember an epoxy for fuel tank repair. I think I may look into that. Hey, was the JD diesel or gas? That may make a difference.
Old Nov 21, 2009 | 11:58 PM
Daddyo's garage
I did a quick search on the web and epoxy should work! Their are several epoxy sealers and puttys available. I just gotta find the right one. I'll keep you posted! Thanks for the suggestions!
Old Nov 22, 2009 | 10:48 AM
carnut122's Avatar
carnut122
In that case, I vote for JB Weld.
Old Nov 22, 2009 | 06:27 PM
Daddyo's garage
Yup, now all I gotta do is figure out how to get my hand into the sending unit opening to smear the stuff on the tube and jam it into the fitting! No problem! I'll just get small!
Old Nov 23, 2009 | 02:37 AM
55 f350's Avatar
55 f350
i've used jb to repair cracks in between freeze plugs in a dirt track car i had and it never leaked and i beat the hades out of it and reringed it twice . so yep the stuff works if you do what the directions say !!!!!!!! and yes peeps still repair / weld on tanks . both radiator shops here do it . but ellenburgs has gotten kinda price goofy since the old man isn't there anymore , and a-z is only about a mile from me . i've had my tank in their 3 times for patching etc. now . one of thses day's i'l replace it maybe ........................... oh i stuffed the chevelle in question { yes i used gms for the dirt cars as they were cheap compared to my fords !!!!!!!!!} into the concrete wall at macon with a little help running about 70 nose first . didnt even chip the jb , but it broke the starter off and the water pump got broken off too ................
genscripter
43
Apr 19, 2015 05:50 PM
ah1988
13
Sep 26, 2010 01:22 PM
mmmPowerStroke
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Jan 19, 2006 09:28 PM
mmmPowerStroke
Feb 7, 2005 07:37 PM
rrawlins
28
Sep 12, 2003 09:47 PM
