need help quick: intake bolt removal
Old Nov 18, 2009 | 04:07 PM
RRranch's Avatar
RRranch
How do you get that front lower intake plenum bolt out on the right side? I had to pull the turbo to get one of the back ones on the left side now the front on the other side is jammed into the HPOP resovoir. Thats not coming off. I know there is a trick to these things, just can't see it.
It's on my 94 powerstroke f350.
Old Nov 18, 2009 | 04:34 PM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
If it's the one I am thinking of, it's the same corner either way (heads are the same just flopped front to back.)
And that hole in the intake is notched, so all you do is back the bolt out a little then the intake slides out from under it.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old Nov 18, 2009 | 05:00 PM
RRranch's Avatar
RRranch
It wasn't notched on either of my trucks. It is now though. I got mad and took and cut a slot in it with a chisel to slide the intake out then I notched it.
Those things were leaking terrible on my truck. Boost pressure was barely 10 psi cold. about 5 when it was hot. Less than half of what my 97 gets. All that was wrong was all the sealant was blown out under the plenums and they were loose.
Old Nov 18, 2009 | 07:31 PM
Neal 97 250's Avatar
Neal 97 250
It is supposed to be notched. Atleast my '97 was. They may not have notched the '94's.
guzzler96
19
Sep 28, 2025 07:57 PM
AK FORD GUY
Oct 20, 2011 03:58 AM
andyman91
Jan 31, 2010 03:27 PM
norcalcapri
1978 - 1996 Big Bronco
Jan 24, 2005 11:16 AM
