Is a current draw common??
Old Nov 18, 2009 | 11:26 AM
Ibuildembig's Avatar
Ibuildembig
Have an 86 F350 4x4 with a transplanted 7.3 out of a 92. Just curious what could be drawing on the truck as it sparks pretty good when I hook the battery cables up. It has no stereo and is completely stock other than the motor swap. Thanks
Old Nov 18, 2009 | 11:32 AM
axe_handle's Avatar
axe_handle
My truck does not do this.
Old Nov 18, 2009 | 12:22 PM
Ibuildembig
I unplugged the engine harness and tried it again and it still does it....so its nothing to do with the engine swap wiring. Wonder what in the heck could be drawing enough to spark
Old Nov 18, 2009 | 12:51 PM
tbone91's Avatar
tbone91
Check for any lights being on that shouldn't be -- dome, glove box, brake, parking, etc.
Hmm ... maybe a leaky diode in the alternator? Try temporarily unhooking the alternator and see if it helps.
Does the truck have a brake controller?
Old Nov 18, 2009 | 12:56 PM
Ibuildembig
Ok I took the feed wire that goes to the solenoid off the alternator and the spark went away. What does this mean for my alt?
Old Nov 18, 2009 | 03:04 PM
Hamberger's Avatar
Hamberger
Time to replace the Altinator
Sound like it is time to replace your altinator. Note, always good practice to change your regulator (mounted around the drivers side fender I believe) as well.
Sometime installing a new altinator can finish off an old regulator. Best to do it all at once. Not worth taking a chance on your new diodes in your new altinator in my mind.
Seb...
Old Nov 18, 2009 | 03:14 PM
Ibuildembig
I think a 1 wire powermaster will fix it then....and delete all the factory regulator crap
Old Nov 18, 2009 | 10:57 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Some of the one wire setups need to see rather high RPM's before they start charging.
That is about the only drawback though.
I have a friend that installed a Power Master one wire on his gasser, and he complained it did not charge.
So I went on the Power Master site and found that they must see 2500 to 3000 RPM before they start charging.
You would have to take the pulley diameter difference into consideration to calculate that alternator RPM into engine RPM though.
Old Nov 19, 2009 | 03:01 AM
LCAM-01XA's Avatar
LCAM-01XA
Or you nca simply drop in a factory Ford 3G alternator and enjoy 130 amps of goodness on the cheap
Old Nov 19, 2009 | 09:34 AM
Ibuildembig
I have 3 powermasters on other projects with no complaints....in fact the one on my crawler does 157A at idle. I have messed with 12 volt electronics all my life, I had just never heard of the diode issue...guess cause I usually replace the alternator the very first thing lol. I am not a 3G guy honestly, we tried one on 2 different crawlers and they wouldn't keep up with the injection much less the winch, lights, stereo etc. I know some people have great luck with them, I just don't take chances anymore Thanks for all the help diagnosing my issue!
Scot
Jan 30, 2015 10:54 AM
Sberry27
Electrical Systems/Wiring
Oct 16, 2014 07:32 AM
4tl8ford
Dec 6, 2007 07:27 PM
badblueoval4life
Offroad & 4x4
Jul 12, 2007 08:35 AM
