Front and Rear Diff Question
Old Nov 17, 2009 | 07:26 PM
Dirtrider0213's Avatar
Dirtrider0213
Question Front and Rear Diff Question
What is the recomended weight for my front and rear diff? Do you not put the same in both? Synthetic in either?
Old Nov 17, 2009 | 07:45 PM
Izzy351's Avatar
Izzy351
LOL.... That's the magic question it seems. First, what truck do you have? 250/350 with single rear wheels, or 350+ dually?
The diff for SRW gets 75w-140 syn, the front *can* get the same, according to Ford. Front was supposed to be straight 90w, IIRC. But most folks use syn 75w-90 if not the 75w-140. Personally, I would use syn 75w-90 in the front & 75w-140 in the rear for SRW trucks. For duallies, they also originally had 75w-90 in the rear, but were also apparently switched to 75w-140. I would stick to 75w-90 per Dana.
BTW, I stopped by my local Ford dealership, and asked why they changed the specs. Their answer was "Because we quit making 75w-90". So pick one and go with it, I guess. Does this help or not? LOL
Old Nov 17, 2009 | 07:46 PM
BadDogPSD's Avatar
BadDogPSD
Front- 75W90, takes just under 3 qts
Rear- 75W140, takes about 3.5 qts
For the rear, either get the gear oil that has the friction modifier or you'll need to add some if you have a limited slip. Go with synthetic.
Old Nov 17, 2009 | 07:48 PM
Ponyboychris's Avatar
Ponyboychris
That is the critical part of this discussion.
Old Nov 17, 2009 | 07:50 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
This may help you.
axlelube.pdf
Old Nov 17, 2009 | 08:39 PM
Dirtrider0213
Mine is a 250 SRW. I work for John Deere so i would like to put our gear lube in it cause i can get it right at work, But all we have 70-90 or 80-140 and/or 85-145 and i can get those in synthetic, any of those work?
Old Nov 17, 2009 | 09:31 PM
Izzy351's Avatar
Izzy351
Out of those choices, 70w-90 for the front, and 80w-140 for the rear. Definitely go syn, and add the FM if that fluid doesn't have it if you have a LS rear diff.
Old Nov 17, 2009 | 09:48 PM
Dirtrider0213
Ok thank you all for the help! I am going to see what i can get at work tomorrow. I think i am just going to get some friction modifier for my LS rear end at an auto parts store.
Old Nov 18, 2009 | 12:26 PM
brian42's Avatar
brian42
Veteran: Navy
You can buy a 4oz bottle of modifier from a Ford parts department and it's not that expensive.
Primerranger
1983 - 2012 Ranger & B-Series
Dec 27, 2013 12:06 AM
LeoJr
Feb 28, 2013 05:04 PM
bobalonius
Apr 6, 2012 05:19 AM
wmiller
Jul 20, 2008 01:53 PM
Rich in CO
1997 - 2003 F150
Nov 13, 2006 07:24 PM
