Black coolant
Old Nov 15, 2009 | 10:21 PM
BCWildman's Avatar
BCWildman
Black coolant
Whazzit mean when your coolant is black?
Fresh oil, fresh coolant, 40 km drive then black coolant, oil fine.
Exhaust looks white out of both sides (dual exhaust).
Compression good - 130-140.
Slight puffing noise from #1.
Old Nov 15, 2009 | 11:41 PM
DBGrif91's Avatar
DBGrif91
How many miles are on the engine? When was the last time the coolant system was flushed?
Old Nov 16, 2009 | 12:53 AM
Old93junk's Avatar
Old93junk
What year?........Which Engine?
Sounds like a head gasket leak, exhaust / coolant. Try pressure testing, inspect all spark plugs for evidence of coolant. Does there seem to be pressure in the radiator long after it has cooled down? If the steam is still coming out of the tailpipes after it is completely warmed up, I would think this might be a strong possibility.
Old Nov 16, 2009 | 09:29 AM
jplinville's Avatar
jplinville
My money's on the head gasket...
Old Nov 18, 2009 | 09:01 PM
BCWildman's Avatar
BCWildman
'91 351
Pulled the heads and the gaskets are mint.
The coolant level goes down fast and it runs better without coolant.
Old Nov 19, 2009 | 07:13 AM
fishforlife2007's Avatar
fishforlife2007
well judging by the whole smoke out the tail pipe issue i would also assume the head gasket, but it seems as if you have already checked that.... ive been working on cars everyday for the past 10 years, and have yet to see a car with black coolant.... maybe your truck has a dark force coming down upon it..lol..
Old Nov 19, 2009 | 08:47 AM
jplinville's Avatar
jplinville
I'd now check for cracks between the cylinder walls and the water jackets. Your description is classic for either a head gasket or a cracked block.
Old Nov 19, 2009 | 01:54 PM
nyteshades's Avatar
nyteshades
Cracked head would be my guess. Same thing happened on my 351.
Mr Boogie
6.4L Power Stroke Diesel
31
Feb 17, 2017 07:39 AM
dillehay
Jan 10, 2013 08:28 PM
vlietracer64
Nov 2, 2011 09:09 PM
8525ford
Jul 27, 2009 11:16 PM
don77
23
Jan 1, 2009 09:20 PM
