Fluid change & external filter installed today
I used a 5 gallon bucket to hold the fluid so I would know how much to go back with. To replace what will come out of the pan(4x4) and the converter, will take 16 quarts to fill it back up......add 1 if you installed the external tranny filter.
The DP-Tuner "no start" tune came in handy (so it wouldn't crank) when I was bumping over the engine to find the drain plug on the torque converter.
If you get this filter, I highly recommend the gauge. Before I knew I had a small leak, you could see the needle on the gauge flunctuate a little. I checked all the connections and found out I didn't have one of the flared fittings tight enough. After I snugged it up, the gauge was steady.
Anyway, if your looking for a good article to read, check out "Rejuvenation by Filtration" in the Jan. 2010 Diesel World.
However, if you HAVE had a failure, then by all means put it in the return line to keep anything already lodged in the coolers from getting back to your new trans.
So, I'd think that the answer about where to put it should be determined by whether you've already had a failure.
An in-line filtration system should lessen the chances of a major failure by keeping the fluid cleaner than just recirculating the same suspended wear materials over and over.
A couple of high-gauss magnets placed in the system somewhere couldn't hurt, either.
Pop
BTW, why would it matter where it was installed if the tranny does fail? If it fails, no matter where the filter is located, it is still going to fail.
Different strokes for different philosophies.
Magazine articles are great for those who don't think it through for themselves. Most of the knowledgeable on this forum could write articles for magazines as well as those who are doing it, and in fact, some do.
Most just write here, though.....
Pop
Although I'm new to Diesels, I'm no spring chicken when it comes to automotive repair. Being not only ASE certified, but Ford Certified for the last 30 years in several areas, I don't just believe everything I read. I don't let magazines "think for me", but if I read an article written and backed up with facts that come from research, I will listen. In other words, I'll never be too old to learn!I think the manufacturer of the kit has the same idea as the author of the article. Maybe these guys know what they're talking about....since this is what they do....not just a hobby. If the vehicle has any time on the clock, some stuff is probably already stuck in the cooler. Thats why it is installed in the return.
I installed the filter per the instructions from DieselSite and I think Mr.Riley is a very experienced and reputable Diesel tech. If he says to put it in the return line, thats where I'm puttin it.
The filter on my truck is made from the same basic components as Bob's kit, but I put it together myself, as I'm not sure he was even selling a kit back when I did mine. I'm not sure he was even in business then.
I've installed an external filter on each vehicle I've owned since a '91 Caravan with an A-604 cursed my life. After paying for the last of FOUR trannies that went into that POS, I solved the longevity problem with filtration and some high-gauss magnets to collect the metallic "soot", rather than let it recirculate through the bearings, bushings, and seals. I have never had another transmission failure, knock wood.
Thanks for listing your professional credentials, but I gotta' tell you that "Ford Factory Trained" doesn't hold a lot of weight around here. Those of us who are able to help solve the problems developed in the aftermath of a visit to those same "professional mechanics" know what I mean.
Your reference to "hobby" isn't exactly accurate, either, but I'd be the last to call myself a professional. I tell my customers to "never call me a professional", as I spend a fair amount of my time nowadays fixing their work. Getting paid for the job, right or wrong, seems to be the only criterion these days to carry that title.
In other words, I hope I'm never too old to think for myself.
Pop
American Air- how much was the kit and what trans fluid did you use, also cost of that? Thanks.
I would use a solvent used to flush out refrigerant systems to back-flush the coolers. But only if you really think it necessary.
I would maintain that a properly-maintained transmission, that has never failed (created a bunch of gunk), having the pan occasionally cleaned and the fluid changed routinely, will have nothing to flush out of the coolers except oil.
Mark Kovalski would know for sure from his days at Ford.
Mark????
Pop
