I was looking for an answer for an Expedition problem without much success when I found this forum. It looks pretty active, so hopefully someone can help me out.
The right turn signal on my '04 Expedition started flashing quickly a few weeks ago. Before I had a chance to check it out, it started working again. The other day it started acting up again... the right-front turn signal was out.
Today I replaced the bulb, but it's still not working. The old bulb looked OK, but I put the new one in anyway.
I checked the emergency flashers... all work except right-front, does not flash quickly. The wires seem to be well connected to the at the plug.
Could it be a bad flasher unit? Will they go bad on only one light?
