Van turbo differences
Old Nov 14, 2009 | 05:52 PM
papadelogan's Avatar
papadelogan
Snowboard season cometh..
I stumbled on to a van turbo today but I'm not sure if there were different versions like there are with the trucks. It's definitely a PSD, but I'm not sure if there are generations like with the trucks.
Truck generations for the turbo are:
OBS PSD
E99 PSD
99.5+ PSD
I'm assuming there is one as well for the vans, I just have no idea what it is, and what the differences are between them. Can someone enlighten me? I don't have access to the van 24/7, but the build date is 10/98. And yes, the HPOP was already gone...
Old Nov 14, 2009 | 05:57 PM
UNTAMND's Avatar
UNTAMND
Does the van have a different hpop as well or something or you just wanted to grab it for a spare. I have beentrying to get an obs psd engine for three months just because it only costs 100 dollars. What's the difference there also. What can I use on my superduty psd.
Old Nov 14, 2009 | 06:19 PM
7.3 Rocket's Avatar
7.3 Rocket
Vans used no intercooler so they're got a non-wastegated 1.15 exhaust housing I believe.
Old Nov 14, 2009 | 06:33 PM
papadelogan
I have an Adrenaline HPOP but thought it might help someone else out as a core possibly. Can't hurt to have a cheap spare on the shelf!
$100??!!! NICE!!! The shortblocks are the same. The heads, HPOP, turbos and pretty much everything else is different though.
I know of that detail, but is that true for ALL vans? That's what I'm trying to figure out. If I can get this turbo, was there ever only 1 version of the van turbo...
Old Nov 14, 2009 | 06:52 PM
7.3 Rocket's Avatar
7.3 Rocket
Oh ok. Sorry wasn't reading the question properly.
Old Nov 14, 2009 | 08:00 PM
papadelogan
No worries Pete! I appreciate your input all the same!
Old Nov 14, 2009 | 10:29 PM
bdrummonds's Avatar
bdrummonds
To my knowledge there is only one van turbo, It is a turbo out of an E series. Some junk yards/pullaparts call many things a van. I found a listing for a van turbo here locally that turned out to be a F series cab and chassis with a van box on the back. Needless to say that it was just a regular old .84 turbo.
1.15 A/R will be stamped on the exhaust housing of a van turbo, and it will not have a wastegate.
Old Nov 15, 2009 | 04:19 AM
papadelogan
It's definitely a van! I guess I'll be heading back down there today to try and get it off. Everything was coming loose easily enough UNTIL... I went to loosen the forward-most bolt that secures the turbo to the pedestal. 13mm deep well... CRACK. 13mm std depth socket... CRACK. 1/2" std. depth socket... CRACK. They're Craftsman so I went to Sears last night, replaced them, and bought a set of std. depth impact sockets for today's attempt. I think I'll take some PB Blaster with me this time.... Wish me luck!!
Old Nov 24, 2009 | 07:29 AM
Izzy351's Avatar
Izzy351
Did you ever get the turbo, Brendan?
Old Nov 24, 2009 | 07:38 AM
papadelogan
Yep, but decided to (eventually) get a 38r since I'll be moving back to CO at some point. Lag might not be bad at sea level, but when I'm in the mountains @ 9 or 10,000' elevations... yeah, no thanks. I put it up on PSN but will add it here when I get home. Ebay this weekend.
Old Nov 24, 2009 | 08:48 AM
rat49f6's Avatar
rat49f6
Pm sent ...
Old Nov 24, 2009 | 09:06 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Originally Posted by rat49f6
Pm sent ...
Getting them parts together Jim? lol.
Old Nov 24, 2009 | 12:06 PM
rat49f6's Avatar
rat49f6
Thought it might be a e99 and fit my stock ped but i thimk its late 99
Old Nov 24, 2009 | 12:19 PM
papadelogan
Build date on the van was 10/98 if that helps. I might still have access to the van, so there's a SLIM chance of getting the OEM pedestal if you'd need it. Not sure what that'd cost me to get though...
So I take it there IS and early 99 version and a late 99 version of the van turbo?
Old Nov 24, 2009 | 12:30 PM
duck fan's Avatar
duck fan
Because racetruck
No kidding! I was in Denver this summer visiting my parents and the lag plus the smoke was astounding.
