light upgrades
Old Nov 14, 2009 | 08:57 AM
yomow's Avatar
yomow
light upgrades
I need to upgrades on my factory lights . Headlamp & fog lights. it only has 11,200 miles on the Ex. time to start driving it more . I want to do the best upgrades for it. V-10 4X2 Ex.
Thank's ,Don
Old Nov 14, 2009 | 12:10 PM
BostonX73's Avatar
BostonX73
Swapping your bulbs for Silverstars is a quick and cheap upgrade.
You can also swap a brighter bulb in for your for fogs as well.
After that, you can put in 05 style headlights, most people say they see improvement with that design, but you have to do a little surgery on your truck.
aftermarket HIDs are another option, kits around $200. probably some brands listed if you search - fit and finish can be an issue with some kits.
Old Nov 14, 2009 | 12:29 PM
BAJI26's Avatar
BAJI26
I must say Projectors with HIDs!
Old Nov 14, 2009 | 01:08 PM
X-Hibition's Avatar
X-Hibition
Wiring upgrade and better bulbs are nice (I did both), but four 9" lights on a light bar really bring home the bacon.
Old Nov 14, 2009 | 01:46 PM
tdappleman's Avatar
tdappleman
You got any pictures of the light bar?
Old Nov 14, 2009 | 04:06 PM
yomow's Avatar
yomow
lights
I have An 05 Ex. 4X2 V-10 If another 05 light is better ? Let me know !I thought i saw a thead for LED lights that could be installed , on fog lights ?
Thank's , Don C.
Old Nov 14, 2009 | 10:22 PM
BostonX73's Avatar
BostonX73
Sorry, assumed you had the older, pre-05 truck/headlights.
Some of the aftermarket lights have a line of LEDs in them. You can also swap in turns signal bulbs with LEDs.
I've seen LED off road lights on side by sides etc, but haven't seen them in use on the road.
Old Nov 15, 2009 | 08:22 AM
Matt M, PA's Avatar
Matt M, PA
I swapped my fog's bulbs for 9005s. Plugged right in...HUGE difference without lotsa bucks.
Old Nov 15, 2009 | 08:56 AM
soutthpaw's Avatar
soutthpaw
st
I swapped out 80w/100w to Hella bulbs on my headlights. not sure if they are available in the 05 bulb style but they were only about $20 each via amazon or ebay..
For fog lights I run 100 watt Blue Eye bulbs which are awesome.. they are coated to eliminate glare from rain fog snow and really illuminate wet pavement well. again they are about $20 per bulb... they are sealed beam so u have to change the 4" housing that you would find on rubber housed utility lights at any auto parts stores or harbor freight... pics in my album
Old Nov 15, 2009 | 10:48 AM
katiesdad7's Avatar
katiesdad7
I have the 05 and put in HID's. Great investment. Especially if you drive a lot at night.
Old Nov 15, 2009 | 11:44 PM
03-6L-X's Avatar
03-6L-X
Do you have part numbers for the bulbs you used? I ran Hella lights and 80/100 bulbs on my 740 volvo wagon they were great. My understanding was that they were too hot and would not work with the "plastic" lenses. Any information would be greatly appreciated. Pictures too.
Old Nov 16, 2009 | 09:13 AM
katiesdad7's Avatar
katiesdad7
FWIW, HIDs run cooler. About 35 watts.
Old Nov 16, 2009 | 10:11 AM
03-6L-X's Avatar
03-6L-X
What bulbs can you put into 03 lights?
Old Nov 16, 2009 | 10:23 AM
BAJI26's Avatar
BAJI26
Yes they do. I have both 35W and 55W HIDs in mine~!
ohioexwner
Feb 5, 2015 08:24 PM
Jesser02EX
Jan 2, 2015 05:37 PM
jazz77
Jul 14, 2014 12:51 AM
5280
15
Jun 17, 2010 01:12 PM
katiesdad7
Nov 17, 2008 12:11 AM
