Headlight upgrade
Old Jun 13, 2010 | 07:49 AM
5280's Avatar
5280
Headlight upgrade
I would like to upgrade the headlights on my 2000 Ex - one of them was damaged in a recent hail storm, it seems like the perfect opportunity to add better lighting
Are the 02-04 lights plug and play or do I need to make any mods to install them? What about going to the 05's? I know they use a different bulb, I see Clay sells a conversions harness, what about fitting the actual lights? Do the 05' lights put out that much more light then the 02-04 or is the reason for the swap more for looks?
Thanks
Old Jun 13, 2010 | 11:26 AM
rat49f6's Avatar
rat49f6
02 - 04 are plug and play while with the 05-07 you have to modify the header panel and convert the headlight plug
the 05-07 headlights with standard bulbs are brighter than my 02-04 were with silverstar bulbs
Old Jun 13, 2010 | 11:34 AM
5280's Avatar
5280
Any idea how much you have to modify the header panel? I'm not very comfortable cutting on my truck.
Old Jun 13, 2010 | 12:05 PM
izzybird's Avatar
izzybird
http://www.puredieselpower.com/Tech/...Conversion.pdf
Heres a couple pics of the cutout. I saw much better ones somewhere, they had blue tape on the header panel where you were supposed to cut it. I coulda swore I saved it, but cannot find it. Maybe someone else has it, cause they were good pics and really showed where to cut.
Old Jun 13, 2010 | 04:52 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Its not bad to do at all, and if you screw up another header panel is only about $60 from Ed. I am much happier with my 05' headlight output compared to the original ones.
Old Jun 13, 2010 | 04:54 PM
5280's Avatar
5280
Thanks for the responses. I'm going to give the 05' headlights a shot. Now I have to decide if I want to throw a set of HID bulbs in there while I'm at it.
Old Jun 13, 2010 | 05:08 PM
Supercab's Avatar
Supercab
I am very happy with MY upgrade (from '99s) to the '02-'04 style lights, and Silverstar Ultra bulbs-haven't compaired mine to an '07 with stock bulbs, but besides the phsycal difference between the 2 styles I'll bet there isn't enough difference in brightness to worry about.
Old Jun 13, 2010 | 09:10 PM
rat49f6's Avatar
rat49f6
retro-solutions.com will make you bi xenon hid's that have 9007 plug on the truck side and 9008 on the headlight side for $150ish... call them and tell them ur one FTE i think its a 10% discount
Old Jun 14, 2010 | 04:48 AM
kbeefy's Avatar
kbeefy
Super happy w/ my 02-04 conversion, all plug-n-play. Also have a HD relay'd harness and silverstars. That handles all the low-beam stuff... can't compete w/ 8" HID driving lights on hi though.
Old Jun 14, 2010 | 08:27 AM
scratcherky's Avatar
scratcherky
In upgrading 2000 f250 headlights to 02-04 headlights, I see it is plug & play. Exactly what parts do I need?
Thanks,
Don
Old Jun 14, 2010 | 10:35 AM
jasonch's Avatar
jasonch
does anyone know bulb numbers for the silverstar or "like" bulbs. i would lve to have some brighter lights.
Old Jun 14, 2010 | 11:19 AM
kbeefy's Avatar
kbeefy
Thanks,
Don
Just the headlights.
Old Jun 16, 2010 | 12:04 PM
scratcherky
Any suggestions on where I might find a set of the 2002-2004 F250SD headlights?
Old Jun 16, 2010 | 01:59 PM
kbeefy's Avatar
kbeefy
Got mine from eBay.
Old Jun 16, 2010 | 03:44 PM
5280's Avatar
5280
These guys have aftermarket 02-04 HL's for about $80 a pair. 1A Auto : Aftermarket Auto Parts, Car Body Parts, Replacement & New Automobile and Truck Parts | Buy Discount Car & Auto Parts Online
