7.3 to replace 460?
Old Nov 14, 2009 | 07:58 AM
Heatnbeat's Avatar
Heatnbeat
7.3 to replace 460?
I'm in the process of buying a 97 F350 5sp 4wd with a 460 gas motor to replace my 93 F250 5sp 4wd 7.3 ( frame is getting rusty). Will my 7.3 match up to the bellhousing on the F350 or do I have to take the trans and transfer from the 93 along with the diesel?
It will be a couple weeks until I pick up the new truck so I can't even crawl under it and look.
Thanks Guys
Old Nov 14, 2009 | 08:50 AM
farmert's Avatar
farmert
The diesel transmissions have a different bolt pattern than the gassers so it won't work.
Old Nov 14, 2009 | 09:58 AM
Heatnbeat's Avatar
Heatnbeat
Thanks; I suspected as much.
Anybody have use for a 460 ( propane fueled) with trans and transfercase?
Old Nov 14, 2009 | 11:28 AM
Mat J's Avatar
Mat J
where are you located, i need a good runner, but i think shipping might be alot.
Old Nov 15, 2009 | 08:45 AM
Heatnbeat's Avatar
Heatnbeat
I'm in S East PA.
Here's the deal. The truck is a propane powered 460 with 169 thousand on itand it runs good. My buddy says I should just convert it back to gas and sell my 93. But when I look at all those sensors and wires I get a giant HEADACHE! What I really want is a truck with no computers or sensors. Maybe I should just put a carb on it. I could buy a lot of gas for what it would cost to put the 7.3 in it.
Old Nov 15, 2009 | 10:27 AM
Mat J's Avatar
Mat J
some one makes an adapter plate to bolt a carb onto the efi intake. and you cant just switch to a carb intake heads are different. or you can just make an adapter. i would just keep running propane though.
my 7.3 literally gets double mpg then my 460 so that is something to think about.
John in Vegas
New Member Introductions
Sep 25, 2013 03:07 PM
hdthunder02
Sep 23, 2010 07:12 PM
CharlesH85
Feb 6, 2010 02:01 PM
glenn Allen
15
Jul 4, 2007 01:11 AM
jigmup
Jul 25, 2005 06:53 PM
