glow plug harness
Old Nov 14, 2009 | 08:53 AM
northernlights's Avatar
northernlights
glow plug harness
Hey can I get a bullet connector for my harness I have one bad one on a glowplug..
Thanks Craig
Old Nov 14, 2009 | 09:20 PM
northernlights
repair
Any harness repair kits available or am I out of luck and have to kit a new one ????
Old Nov 14, 2009 | 10:35 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Some member here have found bullet connectors of the correct size to replace bad connectors on the ZD 9 glow plug harness.
I can't remember what the correct size was though.
Old Nov 15, 2009 | 09:00 AM
northernlights
thanks
Thanks maybe someelse will remember..
Craig
Old Nov 15, 2009 | 09:58 AM
PLC7.3's Avatar
PLC7.3
I think these are bullet connectors.
NAPA store had these for one member it's a 3M part #
--3M--MNU14-156DFIX--in parentheses it says C-33-1201X---one end fits the pin, the other crimps to 16-14 wire
Also
West Marine GP connectors.
Ancor Snap Plug Connectors, part number 230719.
**** http://www.allelectronics.com/cgi-bi...le_Bullet.html
Old Nov 15, 2009 | 10:31 AM
stangfas's Avatar
stangfas
NAPA definitely has bullet connectors that will work. I just replaced one on my harness. Actual name is Female snap terminal NAPA part #784353. Its real simple: strip wire back, crimp on and plug it back in. You should be good to go.
Old Nov 15, 2009 | 10:42 AM
northernlights
thanks
Allright I will go after work....
Thanks everbody CRaig
