shorten my frame
Old Nov 14, 2009 | 07:07 AM
randrford's Avatar
randrford
shorten my frame
OK after exhausting my resources ( and my phone lol) I have no choice but to shorten my frame in order to convert my 79 F100 to the short bed sporty look I want. Any step by step instructions for cutting and welding are greatly appreciated. Pics of projects would be an added bonus
Thanks !!
Old Nov 14, 2009 | 09:52 AM
bulletsneverlie's Avatar
bulletsneverlie
On Trucks, they did that to a c10. You make a Z joint between the front hanger and the cab, on the straightest section. Some people say to weld a plate over it as well, I'm not sure if it's necessary. I tried to find a swb, the ones I found were in terrible condition, and not for sale. I was going to do the cut, but I realized my grand dad has a swb '69 parts truck down on the farm. I'm just gonna put a '73 body on that '69 frame.
Old Nov 14, 2009 | 06:33 PM
Lrgfather's Avatar
Lrgfather
This link should help you out a little, it shows how to lengthen a frame but the principle is the same for shortening.
NORTH COUNTRY SPECIALTIES
Old Nov 14, 2009 | 06:44 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Hmmm... I would "Z" the frame or diagonal cut the frame rather than introduce those 90 degree cuts into the mess.
As for double plating the frame, most guys re-attach the frame and then back the "inside" of the frame with plate. No need to back both sides of the frame rail, unless you really want to.
Josh
Old Nov 14, 2009 | 06:54 PM
crash1's Avatar
crash1
is it 4 or 2 wheel drive
Old Nov 21, 2009 | 08:07 AM
randrford's Avatar
randrford
THANKS ALOT FOR YOUR HELP !! Ill be gettin started this weekend
Old Nov 21, 2009 | 09:01 AM
hp246's Avatar
hp246
You may want to search the Trucks web site. You may still find the shows online. I think they did that over a couple of shows and got into quite a bit of detail.
Old Nov 21, 2009 | 07:39 PM
bulletsneverlie
double post, please delete.
Old Nov 21, 2009 | 07:44 PM
bulletsneverlie
I was just thinking of a 2wd Bronco with the shell shaved. ~That would be sporty~
Back to reality....
I do think I'm going to have to cut a long bed for my swb swap though.
Old Nov 21, 2009 | 07:56 PM
ranger429's Avatar
ranger429
I'm not a welder, never claimed to be either but from looking at this picture he extended the frame what looks to 12" or so. A Z cut would require a section of frame to be spliced in the middle which I think would weaken the joint connection. From what I can see this is a much stronger joint connection than a Z cut would be. A Z cut would be the best choice for shortening a frame but I don't see how a Z cut would work with what he was doing with this frame.
Old Nov 21, 2009 | 08:15 PM
bulletsneverlie
The cut Ranger 429 is showing is the one I meant. I used the wrong term. I think that would be strongest. You want all the strength you can get on a frame. Barreling down the road at 75 mph and having the frame snap scares the hell out of me. You also have to think how much the frame flexes. My F100 frame seems to move more than the springs do.
Old Nov 21, 2009 | 09:41 PM
Bullitt390's Avatar
Bullitt390
His method of lengthening the frame introduced 90 turns, which can develop into stress cracks in no time. His method is easier and would take far less time I suppose, but I would cringe to see that truck take a railroad crossing at speed.
A "Z" cut would be done to SHORTEN a frame. In the case of lengthening a frame it would have been better to diagonal cut the frame and splice in a new section, with overlapping steel plates on each side of the butt welds. Just about every Class 8 truck that has had it's frame extended is done that way.
A nice example of a "Z" cut...
A diagonal cut would not have the top of the frame rails notched like the Z cut.
Josh
Shawnboylk
May 9, 2016 12:28 PM
Notmeofficer
Oct 17, 2015 08:43 PM
68murc
Ontario Chapter
17
Apr 11, 2015 11:34 PM
randrford
Aug 16, 2009 04:04 PM
ClatonK
Mar 26, 2004 07:32 AM
