Rear end problems
Old Nov 12, 2009 | 07:43 PM
christianawann's Avatar
christianawann
Rear end problems
Hey I'm back and once again an idiot is causing me problems. I was replacing the axle seals in the rear end on my '66 and found on the pside axle the bearing must have came apart and dinged up the housing and when they replaced the bearing the tak welded the retaining ring and struck the ark along the sealing surface and in their infinite wisdom the ground it down to try and make it smooth again. My question is out of what vehicles can i use the 9 inch and just bolt it up so my truck isn't down but a couple of hours. Any help would be appreciated due to the low funding of this truck.
Old Nov 12, 2009 | 11:41 PM
customcab66's Avatar
customcab66
another truck and most thunderbirds in the late 60's early 70' had them as well i think
Old Nov 13, 2009 | 01:46 AM
tbm3fan's Avatar
tbm3fan
Oh, God, spare us from anymore infinite wisdom....... please!
Old Nov 14, 2009 | 02:39 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
NO Passenger Car axle housing will work in a truck. Not a one.
From 1965, some cars had rear coil springs, doesn't really matter though, as all the car axle housings are the wrong length.
1966/72 Thunderbirds, some Galaxie/LTD's and full sized Merc's have a 9" that has a 9 3/8" ring gear.
Only 5 misc internal parts are the same as a 9 inch...nothing else is...including the housing, 3rd member, axleshafts.
1961/66 F100 9" axle housing is the same. Ths is the ONLY housing that will fit.
B7TZ4234A .. Axleshaft / Fits: 1957/67 F100 9" / Right/Left is the same.
Old Nov 14, 2009 | 04:15 PM
banjopicker66's Avatar
banjopicker66
The Ford 9" rear axle from F-100s, '67 - 72 are a direct bolt up. You will need to et the entire axles, though, drum to drum. The brakes, brake backing plates, and axle shafts are not the same internally as the '61 - 66 axles. However, the external dimensions are the same,so that are a direct bolt up replacement.
Old Nov 14, 2009 | 09:47 PM
christianawann
Thanks for all the input I will now go hunting.
Old Nov 15, 2009 | 08:37 PM
ol yeller's Avatar
ol yeller
concur with banjo I got mine out of a 70. whole rearend.
Old Nov 15, 2009 | 10:28 PM
89ford73's Avatar
89ford73
i have a 9" rear end from a 67 f-100. i drove the truck home no problem, i dont know if the internals are any good tho. i live in south texas corpus christi we might be able to make a deal.
Old Nov 16, 2009 | 02:09 AM
NumberDummy
Originally Posted by banjopicker66
The Ford 9" rear axle from F-100s, '67 - 72 are a direct bolt up. You will need to get the entire axles, though, drum to drum.
B7TZ4234A .. Axleshaft-28 Splines / Fits: All 1957/67 F100's (11" x 1 3/4" rear brakes).
C8TZ4234A .. Axleshaft-28 Splines / Fits: Most 1968/72 F100's (11" x 2 1/4" rear brakes).
DOTZ4234A .. Axleshaft-31 Splines / Fits: Some 1970/72 F100's with the 9 3/8" ring gear (11" x 2 1/4" rear brakes).
Even though classified as a 9", this H/D rear end has a 9 3/8" ring gear.
Only 5 parts are the same as a regular 9 inch: Housing gasket, front pinion bearing & race, pilot bearing retainer, and pinion seal.
EVERYTHING else is different.
Old Nov 16, 2009 | 07:17 PM
banjopicker66
Bill (Number Dummy) corrected the one detail on my earlier post that can be misleading.
That is, the 1967 year.
Although the '67 rear axle will bolt up, it is like the '66 with narrow rear brakes.
My post should have said '68 to '72, not '67 - if you want the larger rear brakes, that is.
merten
Apr 15, 2017 02:24 PM
Aaron-71
13
Nov 10, 2016 02:39 PM
Steve1920
1947 and Older Ford Trucks
Sep 3, 2016 11:27 AM
HydroTek
Oct 10, 2012 05:05 PM
Dieselman929
Apr 5, 2004 09:36 AM
