Should i upgrade Distributor
Old Nov 11, 2009 | 12:19 AM
jeff8362000's Avatar
jeff8362000
Im trying to figure out the best and easyest electronic upgrade. Ive heard about a Duraspark and ive also heard about the Petronix. What are the differences and easyest to install. what all comes with each are they the whole distributor or just insides. If some one could explain these to me that would be great. Thanks so much all, Oh by the way i have a 1965 ford 100 with a 240 motor, bored out to .040. Thanks Jeff
Old Nov 11, 2009 | 05:02 AM
jowilker's Avatar
jowilker
Jeff, With the Petronix you just swap your points, and better upgrade with hotter coil.
With the Duraspark you will have to replace the dist. and add the control box.
Both are good upgrades. Hotter spark can improve performance.
John
Old Nov 11, 2009 | 05:46 AM
dogbreath1000's Avatar
dogbreath1000
i did he petronix with a 40 thousand volt flamthrower..works great.idles better,starts easier,runs great...no more points or condenser..easy to install....no regrets..
Old Nov 11, 2009 | 12:49 PM
PerfDistIgnition's Avatar
PerfDistIgnition
FTE Sponsor
It depends on whether a stock appearing distributor is important to you or not.
If you decide to get a new distributor, consider our custom curved Duraspark Distributor built with our new Full Length Oil Impregnated Bronze Bushing. The full length bushing improves timing stability and spark scatter. If stock appearance is not an issue, take a look at our one piece D.U.I. Distributor. Whether you choose the Duraspark or the D.U.I., we curve each on a distributor machine based on your engine combination. Please see them at:
http://performancedistributors.com/forddistributors.htm
Also, there is now an excellent installation article on the D.U.I. Distributor on the Ford-Trucks.com site at:
https://www.ford-trucks.com/article/idx/0/358/article/DUI_Ignition_Installation_In_A_Ford_351W_V8.html
Ignition Lesson of the Month: Hystereses, the difference between the timing as the rpm and vacuum increases to the timing as rpm and vacuum decrease, needs to be kept to a minimum. A precise advance curve accomplishes this.
__________________
FTE Sponsor
Performance Distributors
www.PerformanceDistributors.com
Old Nov 11, 2009 | 04:18 PM
BobbyFord's Avatar
BobbyFord
I'd go with a Pertronix set up because of the cost, ease of installation and virtual zero maintenance. Upgraded spark is not going to make any noticable difference on a 240 engine. JMO.
Old Nov 11, 2009 | 09:17 PM
jeff8362000
Do you think the Petronix upgrade on a 240 would make a big difference.
Old Nov 11, 2009 | 09:22 PM
BobbyFord's Avatar
BobbyFord
Well, you'll never have to replace or adjust points again. I don't know if it will be a noticeable improvement.
Old Nov 12, 2009 | 02:46 AM
tbm3fan's Avatar
tbm3fan
I have Petronix in all my cars. I just recently experimented by changing for I to II in the truck. Put on the higher voltage coil and spliced in a bypass of the pink resistor wire. That plus my change of the intake manifold, using the cork end gaskets, and I achieved a vacuum reading of 20.5 and rock steady both on the needle and idle. We'll see what happens over time and the II goes next into the 410 Mercury.
Old Nov 12, 2009 | 05:26 AM
jowilker's Avatar
jowilker
Jeff, A sick puppy is a sick puppy, there aint a hell of a lot that you can throw at a 240 to get better performance. While the Petronix will get you away from points you will see a very slight improvement with the coil, but if I wanted to throw $125.00 at that engine BOTH the igniter and coil is where I would spend the money. IMHO
Mike, Have you looked at the III yet?
John
Old Nov 12, 2009 | 09:51 PM
jeff8362000
When you say ignighter are you talking about the petronix 1 and a flame thrower coil. Im stupid when it comes to electrical. Thanks Jeff
Old Nov 13, 2009 | 01:43 AM
tbm3fan's Avatar
tbm3fan
John
Yes, I am looking at that for the Cougar which has the much more modified engine in the carb, intake, exhaust, cam and head work.
Old Nov 13, 2009 | 06:04 AM
jowilker's Avatar
jowilker
Jeff, To be honest I haven't compared the I to the II lately. I am not sure which would be better for a 240.
Eliminating point replacement (one shot), slight performance increase, better starts. I seriously would consider buying a Pertronix.
John
Old Nov 13, 2009 | 12:57 PM
charliemccraney's Avatar
charliemccraney
I don't think the Pertronix is worth it from a performance standpoint. When I was using a Pertronix 2 with the 45kv coil, I didn't notice any improvement. After I fried it while doing a compression test, I reinstalled the points and to my surprise, the motor actually felt stronger! This is on a modified but mild motor. Because of that, and the ease of frying the things, I don't plan on using it again. Sure I can carry points around with me and swap them in if it fails but quite frankly, if I feel so uncertain about something that I feel like I need to carry a spare, it doesn't get installed on my truck. The points maintenance really didn't bother me. In the 5000 miles after switch back to points, I did not have to adjust them once.
Now I am running an aftermarket Duraspark ignition and it will eat the Pertronix and points for lunch.
Old Nov 14, 2009 | 11:28 AM
BobbyFord's Avatar
BobbyFord
My Pertronix has been in my truck for 12 years with no problem. I don't think that with the 240/6 he's going to do much to notice any performance increase.
Old Nov 14, 2009 | 12:10 PM
daveengelson's Avatar
daveengelson
As for Electronic Ignition, not familiar with Pertronix but if the only upside was that it would help with starting the truck on a cold winter morning then it would be worth it to me, primarily why I went with E.I. on the 65 with the 390. As for cost, don't believe there would be that much difference between Durapark ll, and Pertronix, have not priced other Electronic Ign. options. Seems Pertronix would be a quik fix and one could add a module; MSD, etc., to the Pertronix distributor at a later date, although, with a 6 cyl, not sure why one would. Anyhow, hand an urge to chime in and add my
