Sponsored by: Kumho
brakes
Old Nov 12, 2009 | 02:23 PM
cole60's Avatar
cole60
brakes
Why dose the inside pad wear out long befor the outside? The caliper moves free not frozen and the out side looked good the inside metal on metal? 2001 f250 sd with v10 4x4
Old Nov 12, 2009 | 02:33 PM
andym's Avatar
andym
Frozen caliper slide pins. When the pads are replaced you should remove the pins, make sure the rubber boots are not torn, and lubricate the slide pins.
Old Nov 12, 2009 | 02:35 PM
cole60's Avatar
cole60
they move free and are clean and regreased They were NOT frozen
Old Nov 12, 2009 | 02:53 PM
andym's Avatar
andym
It's a pretty simple system. There really isn't much to go wrong. If the slides move freely then what you describe can't possibly happen.
Old Nov 12, 2009 | 03:07 PM
Lazy K's Avatar
Lazy K
Rough/scored rotor surface or loose/worn slider pins.
Old Nov 20, 2009 | 09:52 AM
cole60's Avatar
cole60
it is possible i just changed them like that..... Calipers slid nice and smooth. the rotors were starting to warp on me
mosigndude
Jan 17, 2014 09:12 AM
55paneltrk.
Sep 12, 2011 02:18 PM
Fordby4
13
Oct 22, 2010 03:59 PM
pdd
Feb 23, 2008 12:28 PM
78-f150-4x4-351m
General Automotive Discussion
Mar 6, 2005 09:44 PM
