Will it hurt to paint the inside of valve covers?
My valve covers need painting. I plan on removing them, sandblasting them down to bare metal, priming and painting inside and out with high heat engine enamel. I will allow several days dry time. Is painting the inside recommended? Will the paint hold up if done as explained above or will the paint come off and go into the engine? Any suggestions.
Most of the high temp paints i have used for various projects state not to use primer because the primer is not meant for high temp situations and will burn off. Ruining the bond of paint to metal. Unless you are using a high temp primer, which im not sure they make such stuff for the hobbiest. I would skip the priming.
I have had no problems with my painting procedure: sandblast the part, wiping the part down with thiner, (waiting a while), warming the part up by a woodstove, then painting it (away from woodstove) bringing it back awhile later and letting it "bake" by the wood stove.
I'm not sure if it is the routine or just my mind, but the paint seems glossier, and more durable when I "bake" it. Just my opinion.
no need to even sand blast the inside, there is so much oil being thrown around in there, you could even leave it bare, and it SHOULD never rust. if you were dedicated to coating the inside, I would have it powder coated, or HPC coated, this way it WON'T come off.
the valve covers should never get hot enough to cook paint. so just clean the inside really well, and blast, prime and paint the outside. then cover it all with some high temp clear, this will bring out some shine you cannot achieve with just paint.
Inside Man
04-16-2013 08:02 PM
Sherbo
01-01-2012 09:00 PM
Montana Bob
12-22-2004 12:08 PM
